Garbled beep when testing continuity of new EX330
by brittspace on Thu Jan 17, 2013 7:15 am
Just playing with my new EX330 multimeter. I've noticed that when testing continuity by touching the two tips together the beep is garbled before finally settling on a solid tone. Doesn't seem to be a problem on circuit connections.
Is this normal or could it be a sign of a faulty connection in the meter?
Video here: https://vimeo.com/57589484
brittspace
Re: Garbled beep when testing continuity of new EX330
by adafruit_support_bill on Thu Jan 17, 2013 7:38 am
My EX330 does the same thing. So do my other meters. I think it is because the sides of the probes get a layer of oxidation on them and are not the greatest conductors.
by seamus on Thu Jan 17, 2013 1:15 pm
Of the two primary meters I use:
One beeps immediately upon continuity closure, but frequently makes scratchy sounds due to incomplete or light contact.
One has a slight delay built into it, but always produces a clear, steady tone.
I can see the design logic behind both solutions, but it makes one or the other "less than optimal" - or sometimes even useless - for different applications (the unit with the delay, for example, can't be used for toning out brief, momentary contacts). It can be a pain on occasion, but I sometimes need to switch meters, depending on what I'm using them to measure.
I make things.
Sometimes I break things too.
...because variety is good.
seamus
by brittspace on Thu Jan 17, 2013 4:05 pm
Thanks for the quick responses. Read this from bed last night!
brittspace
