G is for GROUND! The latest Circuit Playground is here!
Brass Valve 996 for Propane?
by isdale on Mon Jan 21, 2013 3:46 am
Howdy...
I've been working with some arduino controlled propane flares lately (video)and have upcoming project to take this to a much larger level.
I was browsing thru your catalog and noticed your brass 1/2" 12vdc valve.
I'm not a valve geek so I am not sure - Is this appropriate for gas (propane) as well as the liquid you mention?
I need a half dozen or so and your price is good - and a well known, liked vendor.
Jerry Isdale
Maui Makers
http://mauiMakers.com
isdale
Re: Brass Valve 996 for Propane?
by adafruit_support_bill on Mon Jan 21, 2013 7:54 am
These are designed for liquid and I don't believe they could handle the pressure of a propane tank. For safety, you really want to go with a valve specifically rated for gas.
by isdale on Mon Jan 21, 2013 12:45 pm
adafruit_support wrote:These are designed for liquid and I don't believe they could handle the pressure of a propane tank. For safety, you really want to go with a valve specifically rated for gas.
Drat. I thought the price a bit low for propane rated valves. Will consider again for aquaponics and other liquid projects.
Jerry Isdale
Maui Makers
isdale
by arndorferindustries on Sun Feb 17, 2013 10:35 pm
Hi, I was wondering what the top pressure you would recommend putting on this valve. I have two and one holds up 90psi from an air compressor but the other vacillates and lets the air pass.
arndorferindustries
by adafruit_support_rick on Sun Feb 17, 2013 11:26 pm
The valve is rated from liquid pressures up to 140psi. I have no information on air pressures.
by arndorferindustries on Mon Feb 18, 2013 11:48 am
So I tried various pressures and I think the brass portion of my second valve is faulty because it won't hold any compressed air over 15psi and I swapped the electronic portion of the valves and the working one continued working and the other reproduced the error.
arndorferindustries
by adafruit_support_rick on Mon Feb 18, 2013 12:03 pm
Please email support@adafruit.com with a link to this thread to arrange for a replacement
by arndorferindustries on Mon Feb 18, 2013 5:14 pm
Thanks, I emailed them first but they told me to ask the experts on the forum first.
arndorferindustries
by adafruit_support_rick on Mon Feb 18, 2013 5:24 pm
In your email, you need to include a link to this thread so that they know you talked to us.
