Winter Storm Juno: Blizzard Warning! All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
bmp085 example code trouble
by jws302 on Wed Jan 23, 2013 1:41 pm
trying to implement the adafruit example code for the bmp085, first it didnt like the syntax of the print statements ( which i read in verision 3.2.3 of Python, has become a function. added parentheses, then came up with the error below.
File "/home/pi/Adafruit-Raspberry-Pi-Python-Code/Adafruit_BMP085/Adafruit_BMP085_example.py", line 3, in <module>
from Adafruit_BMP085 import BMP085
File "/home/pi/Adafruit-Raspberry-Pi-Python-Code/Adafruit_BMP085/Adafruit_BMP085.py", line 59
print "Invalid Mode: Using STANDARD by default"
SyntaxError: invalid syntax
i've done some coding in turbo pascal,gwbasic,vb6, delphi6 and just starting to learn python....a kick in the right direction would help.
thank you
jws
jws302
Re: bmp085 example code trouble
by adafruit_support_rick on Wed Jan 23, 2013 3:28 pm
Didn't you put the parentheses around the print statement?
print( "Invalid Mode: Using STANDARD by default")
by jws302 on Thu Jan 24, 2013 12:37 pm
went through and changed all instances of PRINT " " to PRINT (" ") this fixed all related error for PRINT. now have IOERROR, err syntax error.
guess i'll have to crash learn more python.
thanks for your help
i was using adafruits bmp085 code library as is. guess it needs a few tweeks since version B came out, plus says not tested yet.
jws302
