4x20 LCD: Only 2 Lines Work
by DWW on Wed Jan 23, 2013 2:38 pm
This is my first post and I'm quite new to Arduino. I've got a 4x20 RBG LCD and I've followed the LCD tutorial, but it only help me get 2 lines of my 4x20 LCD to work.
This is a guess, but I'm thinking that there must be something that requires changing in the LiquidCrystal.h library so that I can get all 4 lines to work?
If you have any suggestions, please let me know.
DancesWithWords
DWW
Re: 4x20 LCD: Only 2 Lines Work
by adafruit_support_bill on Wed Jan 23, 2013 2:46 pm
In setup(), change lcd.begin(16, 2); to lcd.begin(20, 4);
  // set up the LCD's number of rows and columns:
  lcd.begin(20, 4);
  // Print a message to the LCD.
  lcd.print("hello, world!");
by DWW on Wed Jan 23, 2013 3:49 pm
Tried your solution and received:
sketch_jan22a.cpp: In function ‘void setup()’:
sketch_jan22a.cpp:7:3: error: ‘lcd’ was not declared in this scope
DancesWithWords
DWW
by adafruit_support_bill on Thu Jan 24, 2013 6:20 am
What name did you use for your liquid crystal object?
If you declared
LiquidCrystal xxxxx(12, 11, 5, 4, 3, 2);
Then you call
xxxxx.begin(20, 4)
in your setup()
by DWW on Thu Jan 24, 2013 12:25 pm
I got the LCD working with the following:
#include <LiquidCrystal.h>
 LiquidCrystal display with:
 LCD 1 (0V) to arduino ground pin 14
 LCD 2 (5V) to arduino +5 V
 LCD 3 (V0) to output from potentiometer 10kOhm connected between +5 V and GND
 LCD 4 (RS) to arduino pin 12
 LCD 5 (R/W) to arduino ground
 LCD 6 (E) to arduino pin 11
 LCD 11 (DB4), 12 (DB5), 13 (DB6), 14 (DB7) on arduino pins 7, 8, 9, 10
 LCD15 (LED+) through resistor 12 Ohm to arduino +5 V
 LCD16 (LED-) to arduino ground
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
void setup()
  lcd.begin(20, 4); //lcd.begin(columns, rows)
  lcd.setCursor(2,0); // Position cursor on line x=3,y=1
  lcd.print("4x20 LCD DISPLAY"); // Print a message to the LCD
  lcd.setCursor(3,1);
  lcd.print("with controller");
  lcd.setCursor(7,2);
  lcd.print("HD44780");
  lcd.setCursor(1,3);
  lcd.print("useful for Arduino");
void loop()
I was wondering how does one do a scrolling message?
DWW
PS. Really appreciate the prompt help.
Reason: Changed quote to code in tags
DWW
by adafruit_support_bill on Thu Jan 24, 2013 3:04 pm
There is an "Autoscroll" example sketch in the LiquidCrystal library examples.
by DWW on Mon Nov 17, 2014 1:05 am
Thanks for the Autoscroll. I'm working on a new feature of this RGB LCD and that is to get the colour to rotate. I'm using your sketch from: https://learn.adafruit.com/character-lcds?view=all, but that only get me the message, not the rotating colours.
I've noticed that this LCD (WH2004A) has 18 pins and that the last 3 (pin 16 red, 17 green, 18 blue) control the colours. Am I right about that?
I thought if I changed:
#define REDLITE 3
#define GREENLITE 5
#define BLUELITE 6
to
#define REDLITE 16
#define GREENLITE 17
#define BLUELITE 18
That would fix my problem, but it did not? Could you suggest a solution? Thanks
DancesWithwords
DWW
by adafruit_support_bill on Mon Nov 17, 2014 7:34 am
Post a photo showing your wiring. Use the example code as-is. You will need jumpers from Arduino pins 3, 5 and 6 to LCD pins 16, 17 and 18.
by DWW on Mon Nov 17, 2014 10:36 am
Is there a restriction on image size for upload? Mine are being rejected as invalid?
DWW
by DWW on Mon Nov 17, 2014 10:59 am
This are my pic's of the set before any changes to pinning where done.
DWW
by adafruit_support_bill on Mon Nov 17, 2014 11:08 am
There is a 1 meg limit for posting photos. 800x600 is a good size.
For the example sketch to work, you need jumpers from Arduino pins 3, 5 and 6 to LCD pins 16, 17 and 18.
by DWW on Mon Nov 17, 2014 11:15 am
Tried that pinning and I see no change in colours though I do get the a display.
DWW
DWW
by adafruit_support_bill on Mon Nov 17, 2014 11:48 am
Please post a photo showing your wiring and the exact code you are using.
by DWW on Mon Nov 17, 2014 11:57 am
THE CODE:
// include the library code:
#include <Wire.h>
#define REDLITE 3
#define GREENLITE 5
#define BLUELITE 6
// initialize the library with the numbers of the interface pins
// you can change the overall brightness by range 0 -> 255
int brightness = 255;
  lcd.begin(20, 4);
  lcd.print("RGB 16x2 Display  ");
  lcd.setCursor(0,1);
  lcd.print(" Multicolor LCD ");
  pinMode(REDLITE, OUTPUT);
  pinMode(GREENLITE, OUTPUT);
  pinMode(BLUELITE, OUTPUT);
  brightness = 100;
  for (int i = 0; i < 255; i++) {
    setBacklight(i, 0, 255-i);
    delay(5);
    setBacklight(255-i, i, 0);
    delay(5);
    setBacklight(0, 255-i, i);
    delay(5);
void setBacklight(uint8_t r, uint8_t g, uint8_t b) {
  // normalize the red LED - its brighter than the rest!
  r = map(r, 0, 255, 0, 100);
  g = map(g, 0, 255, 0, 150);
  r = map(r, 0, 255, 0, brightness);
  g = map(g, 0, 255, 0, brightness);
  b = map(b, 0, 255, 0, brightness);
  // common anode so invert!
  r = map(r, 0, 255, 255, 0);
  g = map(g, 0, 255, 255, 0);
  b = map(b, 0, 255, 255, 0);
  Serial.print("R = "); Serial.print(r, DEC);
  Serial.print(" G = "); Serial.print(g, DEC);
  Serial.print(" B = "); Serial.println(b, DEC);
  analogWrite(REDLITE, r);
  analogWrite(GREENLITE, g);
  analogWrite(BLUELITE, b);
Last edited by adafruit_support_bill on Mon Nov 17, 2014 12:14 pm, edited 1 time in total.
Reason: Fixed [code] tags
DWW
by DWW on Mon Nov 17, 2014 12:36 pm
These two pics are with the pins 3,5,6 connected to 16,17,18
DWW
