Can't read serial from MT3339
by sflo344 on Fri Jan 25, 2013 6:45 pm
I am using the Ultimate GPS breakout board with an Arduino Micro and can't get to read serial either using SoftwareSerial or direct serial using the examples provided.
http://learn.adafruit.com/adafruit-ulti ... ter-wiring
I get to write to serial and get output on the Serial monitor but when connecting the GPS to RX, TX as mentionned, with empty setup() and loop(), I get nothing with 9600 bauds.
The red led flashes every second as there is no fix, even after an hour.
Is there any other way to troubleshoot?
sflo344
Re: Can't read serial from MT3339
by adafruit_support_bill on Sat Jan 26, 2013 7:10 am
Post a photo showing how you have everything connected.
by sflo344 on Sat May 25, 2013 4:27 pm
I gave it another try. Hooked it up as direct connect (http://learn.adafruit.com/adafruit-ulti ... ter-wiring) and uploaded the 'blank' sketch. Can't get any output from the GPS' serial.
You're help is appreciated.
sflo344
by WethaGuy on Sat May 25, 2013 7:11 pm
TX/RX is reversed. Switch the TX and RX on the Micro and you should be in business.
WethaGuy
