Adafruit - THE MUSICAL - is here! Get a musical tour of Becky's favorite tools around the Adafruit factory (video) and subscribe!
Problem with mini thermal printer
by chiggers on Sun Jan 27, 2013 7:44 pm
It appears that there is a problem with my thermal printer. :( After doing
a bit of investigation, I have the exact same problem as these two folks do:
viewtopic.php?f=19&t=35488
viewtopic.php?f=19&t=33102
I got the sample twitter arduino sketch to work in the tutorial, but I got
the similar results as the person in Link 1. I would get a line of dots and
then the last few letters of the tweet in the second line.
I took the arduino out of the circuit and just tried to print the test
pattern by holding down the pattern while powering on (I ordered the starter
kit), but I only got the line "CP437" repeating over and over.
Thanks in advance!
chiggers
Re: Problem with mini thermal printer
by chiggers on Sun Jan 27, 2013 7:53 pm
Well, I fixed my own problem. Perhaps the connections weren't tight enough to the Female DC Power adapter to screw terminal block? I removed the wires from the terminal block, reinserted ,and then retightened. Walah! The green light seems to be pulsing brighter too. So, I guess the printer was getting power but not enough?
Anyway.. hope this may help someone else with the same problem!
chiggers
