16 Channel PWM Servo Driver
by ajpollme on Mon Jan 28, 2013 11:10 am
I am trying to use the PWM function on this to run a few SSRs connected to heating elements for an all electric home brewing set up. The tutorial states that the PWM frequency will go to as low as 1hz, but when I try to set the frequency that low with an led hooked up for testing it is still running quite a bit faster than 1hz more like 10 to 20 hz (I don't have an oscilloscope to check it but it is noticeably flickering). So can I really set this to 1hz or is there a typo in the tutorial?
ajpollme
Re: 16 Channel PWM Servo Driver
by adafruit_support_bill on Mon Jan 28, 2013 11:46 am
Hmmm. Looking at the chip specs, the upper limit in the documentation is almost certainly wrong. Not sure about the lower limit. I'll look into this...
by ktownsend on Mon Jan 28, 2013 12:12 pm
Sorry, this is a type in the tutorial. The actual range is 40-1000Hz based on a 25MHz internal clock. :(
ktownsend
by ajpollme on Mon Jan 28, 2013 1:53 pm
Thanks, I guess I will have to write code to run the slow PWM on the GPIO pins. I was just hoping to save myself some trouble and use a shortcut.
ajpollme
