Thermal Printer
Thermal Printer
by p25486 on Thu Feb 07, 2013 2:56 am
I'd like to hack my adafruit thermal printer slightly. I want to remove the top bezel and shave off the lengthwise edges to get the printer to fit in a project I'm working on. Any advice on getting the bezel off? Do I just pry at it, or will it fall apart if I do?
How will the printer react if I make the print roll a little shorter? Let's assume that I can do that without causing feed issues.
John
p25486
Re: Thermal Printer
by adafruit_support_bill on Thu Feb 07, 2013 7:56 am
I have not disassembled one, but you should be able to trim the bezel flange with a fine-toothed flush-cut saw without removing it. Just tape over the openings to keep the dust out of the works. I don't think the print-head will have a problem with a narrower roll.
Re: Thermal Printer
by p25486 on Thu Feb 07, 2013 2:38 pm
I plan on removing the metal plate from the back too. It does not appear to act as a heat sink. The project will contain the printer, so there's no worry of exposed circuits on the box itself. The plate weighs a lot, and I'm trying to keep the weight down.
I note that there's a lot of open space on either side of the printing mechanism. if I relocate the LED and button, I could cut things down a lot more than I had planned. I'll take photos.
p25486
Re: Thermal Printer
by p25486 on Mon Feb 11, 2013 12:22 am
I did it. Removed the switch and LED, then I drilled holes in a line from the back (metal plate removed) to mark the paper door mechanism. Then used a fine toothed hack saw to cut off 3/8" or so on both ends. It still works, and fits fine.
I will remount the LED and switch in a diffefent way.
p25486
Re: Thermal Printer
by p25486 on Mon Feb 11, 2013 12:37 am
Here's images of what I did.
After the cut, taped to keep dust out of the mechanism.
Here's the rear wiew with the metal plate removed.
Before the cutting.
p25486
Re: Thermal Printer
by p25486 on Mon Feb 11, 2013 12:39 am
Here's the finished unit after the cut. It still works. I suppose my warranty is void. :(
p25486
Re: Thermal Printer
by p25486 on Mon Feb 11, 2013 12:44 am
Opps, forgot this one, you can see how much I cut.
p25486
Re: Thermal Printer
by peek on Tue May 07, 2013 3:56 pm
interesting, thanks for the post
like
peek
