MCP3008 help?
MCP3008 help?
by rahatmaini on Fri Mar 08, 2013 6:49 pm
I am extremely confused about how I can use a MCP3008 for the Arduino. I have been sent to links about the SPI bus, but I am very much a noob at Arduino. Is there an easy way to learn how to connect the chip to the Arduino and some software examples as well? A tutorial?
Thanks :D :D :D :D
rahatmaini
Re: MCP3008 help?
by adafruit_support_rick on Fri Mar 08, 2013 7:52 pm
Is there some reason you can't use the Arduino's built-in A/D converter? The MCP3008 is more of a Raspberry Pi thing for us, since the Pi doesn't have an ADC.
Re: MCP3008 help?
by rahatmaini on Fri Mar 08, 2013 9:21 pm
You mean to say that the Arduino can convert digital pins to analog??
If that's right, I feel extremely stupid yet extremely thankful!
rahatmaini
Re: MCP3008 help?
by adafruit_support_rick on Fri Mar 08, 2013 9:48 pm
Pins A0 through A5 can be used for either digital I/O or for analog input.
Lesson 8 of our Learning Arduino series covers analog input.
Also, check out section 3 on the Arduino Tutorial page
Re: MCP3008 help?
by rahatmaini on Fri Mar 08, 2013 9:58 pm
Oh no no I want to ADD more analog pins. I need more analog inputs!
rahatmaini
Re: MCP3008 help?
by adafruit_support_rick on Fri Mar 08, 2013 10:37 pm
Ah. Well, if you want to use the MCP3008, then I'm afraid you will have to write a library.
However, one of our I2C 4-channel ADCs would be a lot easier, and you'll get 4 channels instead of 1. You can string up to four of them on an I2C bus, giving you up to 16 channels.
12-bit, 4 channel
16-bit, 4 channel
We do have an Arduino library for these guys.
Re: MCP3008 help?
by ottobonn on Tue Mar 26, 2013 4:32 pm
The MCP3008 has 8 channels, not one.
ottobonn
