Thermal Printer Text Density
iamtomodea
Re: Thermal Printer Text Density
Post by iamtomodea »
Brilliant.
Thanks again for all the help.
iamtomodea
Oh wait. Just one more (one more) thing.
So this is now my code
#include "SoftwareSerial.h"
#include "Adafruit_Thermal.h"
#include <avr/pgmspace.h>
#define TIMEOUT 2000
String message="";
char character;
int printer1_RX_Pin = 5;  // This is the green wire
int printer1_TX_Pin = 6;  // This is the yellow wire
int printer2_RX_Pin = 7;  // This is the green wire
int printer2_TX_Pin = 8;  // This is the yellow wire
//int printer3_RX_Pin = 9;  // This is the green wire
//int printer3_TX_Pin = 10;  // This is the yellow wire
Adafruit_Thermal printer1(printer1_RX_Pin, printer1_TX_Pin);
Adafruit_Thermal printer2(printer2_RX_Pin, printer2_TX_Pin);
//Adafruit_Thermal printer3(printer3_RX_Pin, printer3_TX_Pin);
Adafruit_Thermal *currentPrinter = &printer1;
void setup(){
  Serial.begin(19200);
  printer1.begin(255);
  printer1.setDefault();
  printer1.setTimes(35000,2100);
  printer1.setSize('S');
  printer1.upsideDownOn();
  printer2.begin(255);
  printer2.setDefault();
  printer2.setTimes(35000,2100);
  printer2.setSize('S');
  printer2.upsideDownOn();
  if (Serial.available()) {
    uint16_t startTime = millis();
    do{
      character = Serial.read();
      message.concat(character);
    } while (('\n' != character) && ((millis() - startTime) < TIMEOUT));
  if (message != "") {
    currentPrinter->println(message);
//    currentPrinter->feed(1);
    message="";
    if (&printer1 == currentPrinter)
      currentPrinter = &printer2;
//    else if (&printer2 == currentPrinter)
//      currentPrinter = &printer3;
    else
I have commented out printer three as it isn't connected.
I am getting very strange results, where the printers are feeding one word at a time and then printing diagonally or vertically.
And briefly both at the same time! see attached image.
It seems as if it is jumping out of the first loop and printing the first line after each character.
Also, just for clarity, the code below is what is being used to send strings from processing.
void speak()
 String tweetClean = tweetText.replaceAll("[\\S]+://[\\S]+", " ");
 tts.speak(tweetClean);     //this is for a separate tts function so can be ignored here.
 myPort.write(tweetText);
 delay(10000);
 speak();
iamtomodea
sorry.
the processing code is this
 void speak()
myPort.write('\n');
delay(10000);
speak();
