I believe it applies to the break-out board.Barry914 wrote:Does this apply to the shield or to the breakout board?adafruit_support_mike wrote:We updated our boards to compensate for that problem a few months ago. If you bought your CC3000 since about February, it will share the SPI bus like if should.
CC3000 Breakout SPI Question
- mathmestres
Re: CC3000 Breakout SPI Question
- DigitalCowboy
You have the CC3000 configured to use pin 11 for both IRQ and MOSI? You don't mention what uC you are using but the typical Arduinos only have 2 IRQ pins (2, 3) and most of the tutorials I've seen (including Adafruit) use pin 3 for the IRQ. If you are using something like the Teensy you have more options but still MOSI and IRQ should not be sharing a pin.
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 11 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 3
#define ADAFRUIT_CC3000_CS 4
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIVIDER); // you can change this clock speed but DI
- lina944
In my project I am using a CC3000 breakout board and had several SPI headaches. I tried everything to figure out why the CC3000 was corrupting the bus, and I found it to be the interrupt.
Whenever I want to use other devices with SPI, I just detachInterrupt(0) - in my case it was on Pin 2. Then when I want to use Wifi again, I reinitialize the interrupts. Sidenote: I have an old revision of the board without the tri-state buffer for MOSI/MISO.
Good luck!
Good luck!
