loading modules for ADS1115
adafruit_support_mike
Re: loading modules for ADS1115
You'll need two ADS1x15 objects, each of which knows the I2C address for one of the chips:
adc1 = ADS1x15(ic=ADS1115, address=0x48)
adc2 = ADS1x15(ic=ADS1115, address=0x49)
mglenn12
Post by mglenn12 »
worked like a charm. thanks, that was easy.
mglenn12
Post by mglenn12 »
I have learned a great deal in the last few months and now I'm 'upgrading' to Python 3.2. The program calling the various ADS1115 library files is encountering the conversion errors from 3 to 2. Are there ADS1115 library files in Python 3?
The ADS1115 module isn't part of the core Python distribution at all. They're external code we've written, using the official rules for doing that.
Most of Python exists in the form of an external module though, so the distinction is kind of academic at the language level. The main difference is that the ADS1115 module doesn't come with a standard Python installation.
What are the exact errors you're getting?
vishruth
Post by vishruth »
Can you please share how did you solve the problem of "IOError : [Errno 5] Input/output error"
This is the second module of ADS1115 in which I am facing the problem. Initially it runs fine on breadboard but when I solder it , I face this error. Please inbox me if you are ashamed to post it.
thank you
