some time has passed since the last post for this topic but I get the same output as the last two guys
dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.11-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 8080f480, node_mem_map ba093000
[ 0.000000] Normal zone: 1888 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8620->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ba061000 s11456 r8192 d21312 u40960
[ 0.000000] pcpu-alloc: s11456 r8192 d21312 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1776 bcm2708_fb.fbheight=952 bcm2709.boardrev=0xa01041 bcm2709.serial=0x8b7925b5 smsc95xx.macaddr=B8:27:EB:79:25:B5 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 940832K/966656K available (5722K kernel code, 397K rwdata, 1748K rodata, 384K init, 763K bss, 25824K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80753a48 (7471 kB)
[ 0.000000] .init : 0x80754000 - 0x807b4000 ( 384 kB)
[ 0.000000] .data : 0x807b4000 - 0x808174bc ( 398 kB)
[ 0.000000] .bss : 0x808174bc - 0x808d6254 ( 764 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000013] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000037] Switching to timer-based delay loop, resolution 52ns
[ 0.000332] Console: colour dummy device 80x30
[ 0.001802] console [tty1] enabled
[ 0.001851] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001932] pid_max: default: 32768 minimum: 301
[ 0.002336] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002399] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003672] Initializing cgroup subsys memory
[ 0.003767] Initializing cgroup subsys devices
[ 0.003821] Initializing cgroup subsys freezer
[ 0.003871] Initializing cgroup subsys net_cls
[ 0.003935] Initializing cgroup subsys blkio
[ 0.004042] CPU: Testing write buffer coherency: ok
[ 0.004158] ftrace: allocating 19614 entries in 58 pages
[ 0.052742] CPU0: update cpu_capacity 1024
[ 0.052822] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.052862] [bcm2709_smp_prepare_cpus] enter
[ 0.053014] Setting up static identity map for 0x528478 - 0x5284ac
[ 0.112657] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.112968] CPU1: Booted secondary processor
[ 0.112976] [bcm2709_secondary_init] enter cpu:1
[ 0.113030] CPU1: update cpu_capacity 1024
[ 0.113039] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.132632] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.132886] CPU2: Booted secondary processor
[ 0.132893] [bcm2709_secondary_init] enter cpu:2
[ 0.132925] CPU2: update cpu_capacity 1024
[ 0.132933] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.152713] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.152956] CPU3: Booted secondary processor
[ 0.152963] [bcm2709_secondary_init] enter cpu:3
[ 0.152992] CPU3: update cpu_capacity 1024
[ 0.153000] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.153094] Brought up 4 CPUs
[ 0.153215] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.153248] CPU: All CPU(s) started in SVC mode.
[ 0.154232] devtmpfs: initialized
[ 0.179082] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.181051] pinctrl core: initialized pinctrl subsystem
[ 0.184163] NET: Registered protocol family 16
[ 0.189787] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.190970] bcm2709.uart_clock = 3000000
[ 0.193730] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.193782] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.193837] mailbox: Broadcom VideoCore Mailbox driver
[ 0.193967] bcm2708_vcio: mailbox at f300b880
[ 0.194330] bcm_power: Broadcom power driver
[ 0.194368] bcm_power_open() -> 0
[ 0.194393] bcm_power_request(0, 8)
[ 0.695072] bcm_mailbox_read -> 00000080, 0
[ 0.695104] bcm_power_request -> 0
[ 0.695247] Serial: AMBA PL011 UART driver
[ 0.695396] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.203677] console [ttyAMA0] enabled
[ 1.275890] SCSI subsystem initialized
[ 1.279905] usbcore: registered new interface driver usbfs
[ 1.285577] usbcore: registered new interface driver hub
[ 1.291048] usbcore: registered new device driver usb
[ 1.297959] Switched to clocksource arch_sys_counter
[ 1.333594] FS-Cache: Loaded
[ 1.336822] CacheFiles: Loaded
[ 1.351353] NET: Registered protocol family 2
[ 1.357003] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.364263] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.370969] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.377441] TCP: reno registered
[ 1.380720] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.386705] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.393442] NET: Registered protocol family 1
[ 1.398513] RPC: Registered named UNIX socket transport module.
[ 1.404457] RPC: Registered udp transport module.
[ 1.409226] RPC: Registered tcp transport module.
[ 1.413944] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.421369] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 1.429783] bcm2708_dma: DMA manager at f3007000
[ 1.434576] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.444395] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 1.450920] audit: initializing netlink subsys (disabled)
[ 1.456394] audit: type=2000 audit(1.239:1): initialized
[ 1.478077] VFS: Disk quotas dquot_6.5.2
[ 1.482391] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.491938] FS-Cache: Netfs 'nfs' registered for caching
[ 1.498366] NFS: Registering the id_resolver key type
[ 1.503532] Key type id_resolver registered
[ 1.507727] Key type id_legacy registered
[ 1.512991] msgmni has been set to 1853
[ 1.518708] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.526324] io scheduler noop registered
[ 1.530303] io scheduler deadline registered (default)
[ 1.535787] io scheduler cfq registered
[ 1.542281] BCM2708FB: allocated DMA memory fac00000
[ 1.547312] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.580529] Console: switching to colour frame buffer device 222x59
[ 1.604412] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.612191] uart-pl011 dev:f1: no DMA platform data
[ 1.617673] vc-cma: Videocore CMA driver
[ 1.621771] vc-cma: vc_cma_base = 0x00000000
[ 1.626566] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.632121] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.649437] brd: module loaded
[ 1.658277] loop: module loaded
[ 1.661830] vchiq: vchiq_init_state: slot_zero = 0xba800000, is_master = 0
[ 1.669747] Loading iSCSI transport class v2.0-870.
[ 1.675728] usbcore: registered new interface driver smsc95xx
[ 1.681706] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.887884] Core Release: 2.80a
[ 1.891136] Setting default values for core params
[ 1.896056] Finished setting default values for core params
[ 2.102154] Using Buffer DMA mode
[ 2.105542] Periodic Transfer Interrupt Enhancement - disabled
[ 2.111500] Multiprocessor Interrupt Enhancement - disabled
[ 2.117175] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.121637] Dedicated Tx FIFOs mode
[ 2.125556] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 2.135613] FIQ FSM acceleration enabled for :
[ 2.135613] Non-periodic Split Transactions
[ 2.135613] Periodic Split Transactions
[ 2.135613] High-Speed Isochronous Endpoints
[ 2.161603] dwc_otg: Microframe scheduler enabled
[ 2.161676] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x803d98b4
[ 2.172153] WARN::hcd_init_fiq:413: FIQ ASM at 0x803d9c10 length 36
[ 2.182970] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb80a000
[ 2.193551] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.203074] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.214993] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.225131] Init: Port Power? op_state=1
[ 2.233591] Init: Power Port (0)
[ 2.241640] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.252992] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.264746] usb usb1: Product: DWC OTG Controller
[ 2.273918] usb usb1: Manufacturer: Linux 3.18.11-v7+ dwc_otg_hcd
[ 2.284484] usb usb1: SerialNumber: bcm2708_usb
[ 2.294358] hub 1-0:1.0: USB hub found
[ 2.302652] hub 1-0:1.0: 1 port detected
[ 2.311452] dwc_otg: FIQ enabled
[ 2.311466] dwc_otg: NAK holdoff enabled
[ 2.311476] dwc_otg: FIQ split-transaction FSM enabled
[ 2.311516] Module dwc_common_port init
[ 2.311919] usbcore: registered new interface driver usb-storage
[ 2.322685] mousedev: PS/2 mouse device common for all mice
[ 2.333308] bcm2835-cpufreq: min=600000 max=900000
[ 2.342888] sdhci: Secure Digital Host Controller Interface driver
[ 2.353554] sdhci: Copyright(c) Pierre Ossman
[ 2.362627] DMA channels allocated for the MMC driver
[ 2.398001] Load BCM2835 MMC driver
[ 2.410542] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.421301] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.432042] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.442246] usbcore: registered new interface driver usbhid
[ 2.454371] usbhid: USB HID core driver
[ 2.464047] TCP: cubic registered
[ 2.472893] Initializing XFRM netlink socket
[ 2.481670] NET: Registered protocol family 17
[ 2.490710] Key type dns_resolver registered
[ 2.499816] Registering SWP/SWPB emulation handler
[ 2.510014] registered taskstats version 1
[ 2.518137] Indeed it is in host mode hprt0 = 00021501
[ 2.528468] vc-sm: Videocore shared memory driver
[ 2.537645] [vc_sm_connected_init]: start
[ 2.546796] [vc_sm_connected_init]: end - returning 0
[ 2.557629] Waiting for root device /dev/mmcblk0p6...
[ 2.573511] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.591303] mmc0: new high speed SDHC card at address aaaa
[ 2.602019] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[ 2.613723] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.681526] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.694373] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[ 2.708094] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.714947] devtmpfs: mounted
[ 2.715652] Freeing unused kernel memory: 384K (80754000 - 807b4000)
[ 2.737797] Indeed it is in host mode hprt0 = 00001101
[ 2.938429] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.952721] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.966291] hub 1-1:1.0: USB hub found
[ 2.974771] hub 1-1:1.0: 5 ports detected
[ 3.258265] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.368500] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.380274] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.395806] smsc95xx v1.0.4
[ 3.462686] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:79:25:b5
[ 3.558308] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 3.684494] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c52b
[ 3.697351] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.710103] usb 1-1.2: Product: USB Receiver
[ 3.719850] usb 1-1.2: Manufacturer: Logitech
[ 3.742191] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C52B.0001/input/input0
[ 3.760260] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-bcm2708_usb-1.2/input0
[ 3.792906] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C52B.0002/input/input1
[ 3.811403] hid-generic 0003:046D:C52B.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-bcm2708_usb-1.2/input1
[ 3.813337] udevd[175]: starting version 175
[ 3.859224] hid-generic 0003:046D:C52B.0003: hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-bcm2708_usb-1.2/input2
[ 3.958216] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
[ 4.105860] usb 1-1.5: New USB device found, idVendor=148f, idProduct=3070
[ 4.118806] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.132828] usb 1-1.5: Product: 802.11 n WLAN
[ 4.144886] usb 1-1.5: Manufacturer: Ralink
[ 4.155868] usb 1-1.5: SerialNumber: 1.0
[ 5.021916] cfg80211: Calling CRDA to update world regulatory domain
[ 5.198144] usb 1-1.5: reset high-speed USB device number 5 using dwc_otg
[ 5.338704] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 3070, rev 0201 detected
[ 5.358798] random: nonblocking pool is initialized
[ 5.383954] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 0005 detected
[ 5.427057] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 5.429238] usbcore: registered new interface driver rt2800usb
[ 6.944975] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 7.178269] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 11.647732] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 11.650301] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[ 12.242058] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 13.903261] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 16.516745] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 25.031701] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 470.716374] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 470.735755] nf_conntrack version 0.5.0 (14834 buckets, 59336 max)
i have to admit that I did not get the wirelass usb card from here but would still kindly ask for help with this topic
