Just to be sure, I'd like to know how much current the RTL-SDR dongle consumes. I'm wanting to run it on a Raspberry Pi, so the amount available from the USB port is limited.
Frank
Power usage of RTL-SDR USB dongle
Re: Power usage of RTL-SDR USB dongle
I think that will want more power than the RasPi's USB ports can deliver.
I can't find a datasheet for the RTL2832U, but the R820T datasheet (http://www.superkuh.com/gnuradio/R820T_ ... locked.pdf) defines "ultra-low power" as less than 178mA.. which leads me to think the actual limit is somewhere around 177mA.
A RasPi's USB ports are limited to 140mA, so you'll probably need a powered USB hub to make it work.
