I purchased the Motor Shield Kit v2.0, but i want first to know about how to control and run a stepper motor of 10V or 12V using arduino and other pieces like the L293D or the ULN2803 that both i purchased also.
It is possible, how to ?
Does this document will be ok ? : http://learn.adafruit.com/adafruit-ardu ... tors/parts
How to run stepper 10V or 12V without control shield
Re: How to run stepper 10V or 12V without control shield
Yes. That tutorial will show you how to do it.
So, it is possible to run 10V or 12V using this tutorial and no shield ?
If so, excuse me, why the motor shield ? what advantages of a shield ?
I will use the Super motor nema 17 i purchased also, http://www.adafruit.com/products/324#Technical_Details
I read that it requires 2 bridges "Bipolar stepper, requires 2 full H-bridges!"
How can i connect to the arduino, using 2 bridges (well i have 2) ?
Yesit is possible to run 10V or 12V using this tutorial and no shield ?
The V2 motor shield:why the motor shield ? what advantages of a shield ?
1 - handles higher current motors (1.2A vs 0.6A)
2 - Only requires 2 pins
3 - Can be stacked to control 120 motors with just 2 pins.
Each L293D chip contains 2 full H-bridges. You can connect your motors according to the tutorial.I will use the Super motor nema 17 i purchased also, http://www.adafruit.com/products/324#Technical_Details
