https://www.adafruit.com/products/1535) for my wireless game controller project.
I have not been able to get either of them to send keys. I have run out of ways to test them.
I can get them to pair with my android phone mac and PC but they will not send keys from any of the 12 pins.
The yellow key LED does not light up either.
I have tried multiple power sources different setups, directly soldering to buttons and connecting on a breadboard. I can connect ground to the reset pin and it resets but connecting to any of the 12 key pins it shows no response and have not seen a single keystroke send.
Anything I could be doing wrong?
I recently purchased 2 Bluefruit ex-key bluetooth controllers (Bluefruit EZ-Key bluetooth problems
Re: Bluefruit EZ-Key bluetooth problems
I have not attached this unit to a MAC but just recently built a wireless BT foot pedal and the EZ-Key wired right up and worked first time. I am sending 3 different keyboard signals and all worked flawlessly.
After reading this post (viewtopic.php?f=22&t=53473&p=271328&hil ... ng#p271328)and trying various things, I am fairly certain I just happened to get 2 bad modules.
- inof8or
Are you sure you get good conections wiring up like that?
yes, I am sure. I know in those pictures the connections are not soldered but the 2nd module I did solder the connections, the pictures are for showing the manner in which I was testing it (as simply as possible).
I also tried directly from the ground rail on the breadboard to the various pins.
Would like to get these 2 modules replaced since since I have a project to finish.
Could have ordered 2 New ones and had them by now.
We can't authorize a replacement based on the photos above.. soldering the pin header isn't optional, and it looks like your switch wiring is shorted to the GND rail. I'm slightly surprised that the power connection was good enough to light the LED.
Please post a photo of the actual working hardware and we'll see what we can do.
- adafruit_support_rick
We recently updated our programming jig & we introduced a bug that our tester jig didnt catch - we have figured out the issue, repaired both jigs, and pulled the bad ones. The good news is we know what happened and we're making good ones ASAP - but we have to send you a new module, its not possible to 'fix' the one you have! please email support@adafruit with a link to this thread and ask for a tested EZ-Key.
Thank you for the response and for taking responsibility for the bug. I will be sending the email promptly. It is this kind of honesty that I value and will certainly be happy to purchase from adafruit in the future.
Looks like I may be the newest victim. I recently received 3 new EZ-Key modules and after setting the first one up it paired just fine, but will not send a key stroke. I have not tested the other 2 as of yet, but they all came at the same time so chances are they are all bad.
How do I go about having these replaced? Need to fairly quickly I have to get this project completed in the next 5 days?
Please help!!
Regards,
David
Please help!!
Regards,
David
Please email [email protected] with a link to this thread for replacements. Please ask for tested units
Awesome customer service! Thank you for the quick reply......I did test another unit and it does not work as well so I am convinced the 3rd is bad. I just sent an email to support asking for the procedure to return these 3 and receive 3 new working modules.
Regards,
Regards,
I seem to have another issue with my Bluefruit EZ-Key....I am trying to change the key sent from 2 of the pins #10 and #6 from the default or S and 1. I downloaded all of the software "Gui_EZkey_remapper - the library and processing. executed the software and it found my EZ-Key...it allowed me to target the pin I wanted to change - it then stated that "Checksum Match :) However, when I went to execute the button I got no response back to the computer. I tried several different changes but nothing would work after completing. The buttons would return nothing to the computer. When I loaded the default and hit Send Map Checksum Match :) everything worked as normal for default......what am I doing incorrectly??
I am trying to send a consumer map of "Volumeup" and "Volumedown"
Any assistance would be greatly appreciated.....btw I tried version 1.5.1 of processing with library and version 2 with library....both worked as described above. It seems as if the only thing the EZ_Key will save is the default settings........
Regards
David
Regards
David
- adafruit2
can you change them to non-consumer keys?dcastator wrote:I seem to have another issue with my Bluefruit EZ-Key....I am trying to change the key sent from 2 of the pins #10 and #6 from the default or S and 1. I downloaded all of the software "Gui_EZkey_remapper - the library and processing. executed the software and it found my EZ-Key...it allowed me to target the pin I wanted to change - it then stated that "Checksum Match :) However, when I went to execute the button I got no response back to the computer. I tried several different changes but nothing would work after completing. The buttons would return nothing to the computer. When I loaded the default and hit Send Map Checksum Match :) everything worked as normal for default......what am I doing incorrectly??
I can change them and it reports back that it accepted the change, however, when I press that switch I get "NO" reply back from the EZ-Key module. I can see the green light flash that it is sending a signal, however, nothing is received at the computer it is paired with.
