TTL SERIAL JPEG CAMERA problem
nicolastinc
Post by nicolastinc »
Hi
I bought the TTL SERIAL JPEG CAMERA and i follow all instruction on this link: https://learn.adafruit.com/ttl-serial-camera
but i'm not able to get a good result. So went I push on the button GET Version in the VC0706 software I get a msgbox: Cmd time out. I tried mani thing but no result. So now I need a clue or help.
I tried to find on some post on the forum but I didn't find something.
Here is my soldering
the back and front side of the camera
Here is my connection
all connection
all connection
And here is my programm and the error
My programm and the error
Can you help me about that.
Nicolas
Re: TTL SERIAL JPEG CAMERA problem
The wiring looks correct. Are you sure you have the COM Tool set to use the correct COM Port?
nicolastinc
Thank you for your reply
I did a video and it showed what happen went I do the procedure
Look at this video:
https://drive.google.com/file/d/0BxqwDk ... sp=sharing
My wiring is as the picture show above
Thank a lot before
Nicolas
Thanks for the video. That clearly shows the problem. If you contact [email protected] with a link to this thread, we can send out a replacement.
