I am using the Adafruit_MCP230xx.py library with some recently purchased chips which works fine with 1 exception. How do I check to see if a output port is set? I can read the input ports ok but don't see a way to check which way the output ports are set.
Bill Bell
Read output port on MCP23017
Re: Read output port on MCP23017
Read the LAT register in the MCP23O17 to read what the port has been set to.
How do I read the LAT register? I don't see anything in the MCP230xx library that refers to that.
I figured this out. You have to use the i2c module to read the GPIOA & GPIOB registers.
