adxl 345
steza6624
adxl 345
Post by steza6624 »
hi
I have a adxl345 3 axis accelerometer, I have to calibrate it, I follow your guide and I have an output like that you show but how can I use it?
Thanks for help
Stefano
adxl345 calibration.txt
(642 Bytes) Downloaded 159 times
Re: adxl 345
On each axis, the min and max readings will correspond to -1G and 1G. Midway between them is the value that represents 0G. The simplest scaling is:
scaledValue = (rawVal - zeroVal )/oneGval; // in units of G
steza6624
Re: adxl 345
Post by steza6624 »
Hi
Sorry but I don't understand, I have 12 values for each axis, 2 value for each (six) orientation.
For exemple: Z axis when I flip the wood block upside down, flip the Z axis upside down the Z value don't change, Why? Maybe I broken the sensor?
Regards
Stefano
Franklin97355
Re: adxl 345
Post by Franklin97355 »
Post clear pictures of the device and how it is connected. Then post the code you are running using the code button above the reply box.
Code Button.png (6.65 KiB) Viewed 800 times
