hi
I have a adxl345 3 axis accelerometer, I have to calibrate it, I follow your guide and I have an output like that you show but how can I use it?
Thanks for help
Stefano
adxl 345
adxl 345
- adxl345 calibration.txt
- (642 Bytes) Downloaded 159 times
Re: adxl 345
On each axis, the min and max readings will correspond to -1G and 1G. Midway between them is the value that represents 0G. The simplest scaling is:
scaledValue = (rawVal - zeroVal )/oneGval; // in units of G
Re: adxl 345
Hi
Sorry but I don't understand, I have 12 values for each axis, 2 value for each (six) orientation.
For exemple: Z axis when I flip the wood block upside down, flip the Z axis upside down the Z value don't change, Why? Maybe I broken the sensor?
Regards
Stefano
Regards
Stefano
- Franklin97355
Re: adxl 345
Post clear pictures of the device and how it is connected. Then post the code you are running using the code button above the reply box.
