I'm testing the MPL3115A2 (inside my one story home) using the Adafruit link on the product page. Library loaded and etc.
I live in Miami, FL. I'm practically at sea level if not a half meter or so below in my area.
Altitude reading from the MPL3115A2/library/sketch is 6549x.xx meters.
The reading is definitely incorrect.
Temperature inside the house is OK.
I guess the barometer is OK also. 77.57 Inches (HG)
What is going on?
How do I correct this?
CMHippy
MPL3115A2 Incorrect Altitude (?)
Re: MPL3115A2 Incorrect Altitude (?)
That looks like a software bug in the library. It looks like the library doesn't handle negative altitudes correctly.Altitude reading from the MPL3115A2/library/sketch is 6549x.xx meters.
The :getAltitude() function reads the raw altitude value as an unsigned integer, so negative numbers would appear as very large numbers. I don't have one here to test, but I suspect if you change the uint32_t to a int, it would give you a more realistic reading.
float Adafruit_MPL3115A2::getAltitude() {
uint32_t alt;
write8(MPL3115A2_CTRL_REG1,
MPL3115A2_CTRL_REG1_SBYB |
MPL3115A2_CTRL_REG1_OS128 |
MPL3115A2_CTRL_REG1_ALT);
uint8_t sta = 0;
while (! (sta & MPL3115A2_REGISTER_STATUS_PDR)) {
sta = read8(MPL3115A2_REGISTER_STATUS);
delay(10);
Wire.beginTransmission(MPL3115A2_ADDRESS); // start transmission to device
Wire.write(MPL3115A2_REGISTER_PRESSURE_MSB);
Wire.endTransmission(false); // end transmission
Wire.requestFrom((uint8_t)MPL3115A2_ADDRESS, (uint8_t)3);// send data n-bytes read
alt = Wire.read(); // receive DATA
alt <<= 8;
alt |= Wire.read(); // receive DATA
alt <<= 8;
alt >>= 4;
float altitude = alt;
altitude /= 16.0;
return altitude;
Still having a problem with altitude. I loaded a different library and I'm still getting an incorrect altitude reading. I even went to a building and on the 4th floor I get a small negative number. The temperature reading is correct.
Is there a simplified library that I can use to further test this sensor? What else can I do to verify?
