Hello thanks for the quick reply, im tesing with a raspberri pi 512mb model.
Ive got the i2c pins setup correctly but when i run "i2cdetect -y 1" i get the following:
Barometric sensor - BMP180 -Address Error or Dead??
- killabyte
Re: Barometric sensor - BMP180 -Address Error or Dead??
It looks like you have your clock line connected to the wrong pin. You have it on the SCLK pin (used for SPI) but it needs to be up at the SCL pin (right next to SDA).
- killabyte
It kinda looks like that but however the pinout is like so:adafruit_support_mike wrote:It looks like you have your clock line connected to the wrong pin. You have it on the SCLK pin (used for SPI) but it needs to be up at the SCL pin (right next to SDA).
Yellow - Ground to Ground
Black - SCL to SCL
Red - SDA to SDA
White - 3.3v to VIN
- tdicola
Just to check what happens if you run:
This will check i2c bus 0 which some of the early Raspberry Pi revisions used instead of bus 1 like more recent ones.
i2cdetect -y 0
- killabyte
- adafruit_support_rick
Please email [email protected] with a link to this thread for a replacement BMP180
- killabyte
Hello i received my new sensor, however the same exact issue is happening :( please help.
Not sure if i have another dud or if my pi cobbler could be bad?
Please advise
Please advise
More likely you have some bad jumpers of a bad breadboard. Try moving around on the breadboard. Try some different jumpers.
- killabyte
Hello i just tried two sets of jumpers, along with several positions on my bread board with no avail, any other suggestions?
- tdicola
Do you have any other I2C devices you can test with your Raspberry Pi? Or do you have an Arduino you can test with the BMP180? One tricky thing is that it's possible to damage the I2C pins on the Raspberry Pi if you accidentally power a device with 5 volts instead of 3.3 volts. If the pins are damaged then you won't see I2C devices or be able to talk to them like you see.
- killabyte
i do have another raspberri pi i could try, but unfortunate i wont until i get some more in the mail from other sources.
Ill post back with results
thanks for the help
thanks for the help
- killabyte
Still same results with a different raspberri pi :(
Can you bypass the cobbler and jumper directly from the GPIO header to the BMP180?
- killabyte
Hello i tried using another accessory i just got in the mail. Above is me testing the Matrix keypad on my raspi pi
Seems like everything is working fine connected thru the cobbler and breadboard.
- killabyte
i also just tested the keypad with bypassing the cobbler still working fine.
