http://i.imgur.com/FnZCxZt.jpg
SDCS pin on top, rail on bottom
http://i.imgur.com/wAgVB7L.jpg
DREQ pin on top, rail on bottom
http://i.imgur.com/t3Xj6N8.gif
Here's a clearer picture from one of the recordings.
Looking at this, it seems like the issue is caused by a lack of isolation from the SD chip select pin and the rest of the circuit. The noise is visible in both the arduino I've been using and the VS1053 board (I've checked the power rails and pins on both). I've tried two mega2560s and an uno, neither of which made a difference. Does anyone have an idea of how to fix this? I've included the code I'm using below.
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
#define RESET 9 // VS1053 reset pin (output)
#define CS 10 // VS1053 chip select pin (output)
#define DCS 8 // VS1053 Data/command select pin (output)
#define CARDCS 4 // Card chip select pin a0
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin a1
#define REC_BUTTON 7
Adafruit_VS1053_FilePlayer musicPlayer = Adafruit_VS1053_FilePlayer(RESET, CS, DCS, DREQ, CARDCS);
File recording; // the file we will save our recording to
#define RECBUFFSIZE 128 // 64 or 128 bytes.
uint8_t recording_buffer[RECBUFFSIZE];
Serial.println("Adafruit VS1053 Ogg Recording Test");
// initialise the music player
if (!musicPlayer.begin()) {
Serial.println("VS1053 not found");
while (1); // don't do anything more
musicPlayer.sineTest(0x44, 1000); // Make a tone to indicate VS1053 is working
if (!SD.begin(CARDCS)) {
Serial.println("SD failed, or not present");
Serial.println("SD OK!");
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(10,10);
// when the button is pressed, record!
pinMode(REC_BUTTON, INPUT);
digitalWrite(REC_BUTTON, HIGH);
// load plugin from SD card! We'll use mono 44.1KHz, high quality
if (! musicPlayer.prepareRecordOgg("v44k1q05.img")) {
Serial.println("Couldn't load plugin!");
while (1);
uint8_t isRecording = false;
if (!isRecording && !digitalRead(REC_BUTTON)) {
Serial.println("Begin recording");
isRecording = true;
// Check if the file exists already
char filename[15];
strcpy(filename, "RECORD00.OGG");
for (uint8_t i = 0; i < 100; i++) {
filename[6] = '0' + i/10;
filename[7] = '0' + i%10;
// create if does not exist, do not open existing, write, sync after write
if (! SD.exists(filename)) {
break;
Serial.print("Recording to "); Serial.println(filename);
recording = SD.open(filename, FILE_WRITE);
if (! recording) {
Serial.println("Couldn't open file to record!");
while (1);
musicPlayer.startRecordOgg(false); // use microphone (for linein, pass in 'false')
if (isRecording)
saveRecordedData(isRecording);
if (isRecording && !digitalRead(REC_BUTTON)) {
Serial.println("End recording");
musicPlayer.stopRecordOgg();
// flush all the data!
// close it up
recording.close();
delay(1000);
uint16_t saveRecordedData(boolean isrecord) {
uint16_t written = 0;
// read how many words are waiting for us
uint16_t wordswaiting = musicPlayer.recordedWordsWaiting();
// try to process 256 words (512 bytes) at a time, for best speed
while (wordswaiting > 256) {
//Serial.print("Waiting: "); Serial.println(wordswaiting);
// for example 128 bytes x 4 loops = 512 bytes
for (int x=0; x < 512/RECBUFFSIZE; x++) {
// fill the buffer!
for (uint16_t addr=0; addr < RECBUFFSIZE; addr+=2) {
uint16_t t = musicPlayer.recordedReadWord();
//Serial.println(t, HEX);
recording_buffer[addr] = t >> 8;
recording_buffer[addr+1] = t;
if (! recording.write(recording_buffer, RECBUFFSIZE)) {
Serial.print("Couldn't write "); Serial.println(RECBUFFSIZE);
while (1);
// flush 512 bytes at a time
recording.flush();
written += 256;
wordswaiting -= 256;
if (!isrecord) {
Serial.print(wordswaiting); Serial.println(" remaining");
// wrapping up the recording!
uint16_t addr = 0;
for (int x=0; x < wordswaiting-1; x++) {
// fill the buffer!
if (addr > RECBUFFSIZE) {
Serial.println("Couldn't write!");
while (1);
recording.flush();
addr = 0;
if (addr != 0) {
if (!recording.write(recording_buffer, addr)) {
Serial.println("Couldn't write!"); while (1);
written += addr;
musicPlayer.sciRead(VS1053_SCI_AICTRL3);
if (! (musicPlayer.sciRead(VS1053_SCI_AICTRL3) & _BV(2))) {
recording.write(musicPlayer.recordedReadWord() & 0xFF);
written++;
recording.flush();
return written;
