Hey Bill,
I intend to use two Adafruit 6 cell AA battery packs to power a small robot. However, before building the robot I am building a combo variable power supply / battery charger to refuel the bot and power up breadboards, etc.
With that in mind, can you suggest a male/female plug arrangement where say, the female plug can be soldered to a Perma-proto board located on the bot and the male mate with free end leads that can be connected to binding posts on the front of the charger?
In my dream world I would be able to easily extend the length of the leads going from the bot to the charger to facilitate charging the bot's battery packs.
Thank you for any suggestions may provide.
Battery Pack ID # 248
Re: Battery Pack ID # 248
The 2-pin JST connectors we use on our battery packs and chargers would be a good choice.
We have switched and unswitched breakouts as well as bare connectors. These are the same as what we put on our chargers and processors like the Trinket:
https://www.adafruit.com/products/1863
https://www.adafruit.com/products/1862
https://www.adafruit.com/products/1769
We also have some pre-made cables based on these:
https://www.adafruit.com/products/1131
https://www.adafruit.com/products/261
- RussellJames
Works for me!
- michaelmeissner
If you are going to be attaching and removing the power connector more frequently, I tend to like the 2.1mm power connector better:
- https://www.adafruit.com/products/373
- https://www.adafruit.com/products/369
- https://www.adafruit.com/products/368
- https://www.adafruit.com/products/1125
- https://www.adafruit.com/products/1351
- https://www.adafruit.com/products/1352
- https://www.adafruit.com/products/248
- https://www.adafruit.com/products/875
- https://www.adafruit.com/products/610
- https://www.adafruit.com/products/80
- https://www.adafruit.com/products/743
- https://www.adafruit.com/products/327
- RussellJames
Micheal - your recommendations offer an excellent solution for my power delivery and battery charging needs.
Thank you for taking the time to help out.
