Hello, I've done the https://learn.adafruit.com/adafruit-nfc ... spberry-pi tutorial over and over again trying to get this to work, and having no success.
I'm getting a constant power light, but nothing more than that.
Cycled the power many times, recompiled libnfc a lot too. Tried many different setups, but no luck.
Any ideas?
Cheers
Unable to open NFC device
- tom169
- Attachments
- 2014-10-10 22.56.20__1412979024_86.185.22.185.jpg (580.22 KiB) Viewed 393 times
- 2014-10-10 22.56.40__1412979042_86.185.22.185.jpg (502.96 KiB) Viewed 393 times
- 2014-10-10 22.57.21__1412979058_86.185.22.185.jpg (415.92 KiB) Viewed 393 times
- tom169
Re: Unable to open NFC device
More images
- Attachments
- 2014-10-10 22.53.20__1412978977_86.185.22.185.jpg (709.85 KiB) Viewed 392 times
- 2014-10-10 22.53.28__1412978992_86.185.22.185.jpg (621.22 KiB) Viewed 392 times
- 2014-10-10 22.56.04__1412979008_86.185.22.185.jpg (440.57 KiB) Viewed 392 times
- tom169
Let me know if you want any more images / different angles.
- Attachments
- 2014-10-10 20.55.08__1412978938_86.185.22.185.jpg (557.74 KiB) Viewed 392 times
- 2014-10-10 22.53.04__1412978949_86.185.22.185.jpg (475.87 KiB) Viewed 392 times
- 2014-10-10 22.53.10__1412978964_86.185.22.185.jpg (817.97 KiB) Viewed 392 times
- Franklin97355
The only thing I saw in the images was a few joints that could use solder touch up The jumper pins look a bit iffy but the rest look OK. I don't have the nfc so I'll let the others answer.
- tom169
Thanks i'm going to probably resolder everything in the morning. I've tried to take it off the breadboard and the ground header has come off.franklin97355 wrote:The only thing I saw in the images was a few joints that could use solder touch up The jumper pins look a bit iffy but the rest look OK. I don't have the nfc so I'll let the others answer.
- tom169
I've now checked solders and wired it up in I2C mode, with no success. Is the board faulty?
- tom169
Well I feel silly. It was actually bad wiring from the card to the Pi.tom169 wrote:I've now checked solders and wired it up in I2C mode, with no success. Is the board faulty?
