SI5351A clock jitter
karl_nottkarl
Post by karl_nottkarl »
I just hooked up the SI5351A to a Rigol DS1102E and I'm able to observe the sample code frequencies, however, there's a good amount of clock jitter. If I set the frequency to a whole number using integer only mode, such as 50Mhz (25Mhz * 16 / 8), the frequency holds at exactly 50Mhz.
If I use the same integer only mode to generate a fractional frequency such as 46.875Mhz (25Mhz * 15 / 8), the scope flips between 46.73Mhz and 47.17Mhz, never quite hitting the mark. Is this a function of my base level scope, or is this type of fluctuation to be expected?
Karl
adafruit_support_mike
Re: SI5351A clock jitter
You'll see that on any digital scope. It's basically a rounding error.
DSOs are bascially integer devices. The screen is X units of time wide and Y units of voltage high, and all values fall exactly on one of the integer X-Y points. You can fudge that a little by drawing multiple samples on the screen and taking the average, but that just makes the X and Y unit steps smaller than the resolution of any single sample.
The two frequencies you quoted are 440kHz apart, which translates to a tolerance of about +/- 1us per cycle. What timebase were you using when you took the reading?
karl_nottkarl
Time base was set to 10ns.
Hm.. looks like I bungled the error margin.
The period of a 46.73 MHz wave is about 21.4ns. The period of a 47.17 MHz wave is about 21.2ns. The difference between those is about 200 picoseconds, for a tolerance of +/-100ps.
The DS1102E has single-channel sampling rate of 1Gsps, or 1ns between samples. 100ps is 10% of that, which is a conservative estimate on jitter for the sampling clock.
karl_nottkarl
Thanks for the clarification, much appreciated. On a side note, what type of scope was used in the guide for this part. It seemed to have captured the numbers perfectly in the screenshots.
I don't know that one personally, but the images show it's a Tek sampling at 5Gsps, and the frequency counter goes to 1GHz. I'd put it somewhere in the DPO4000/4100 series.
I'll ask around.
adafruit2
Post by adafruit2 »
hiya, finally an easy Q for me :) It's an Tek MDO3104 which is pretty nice except i cant figure out how to measure with cursors. to be completely honest, it was given as a gift from tek - i probably would not have shelled out for it! my previous scope, the TDS2014 is still much beloved!
karl_nottkarl
That's quite a gift. :)
I wanted to give this thing a decent test, so had it replace an 8Mhz crystal for a microcontroller and also provide the 3.579545Mhz clock to a contact javacard, successfully passing data over a t=0 protocol.
The one thing I did see in the datasheet which I couldn't find any further detail on was configuring the Si5135A's nvram to store a default configuration. Is that something that can only be done at factory time?
Without that kind of defaulting, replacing the crystal on a microcontroller first seems to involve having something else (another microcontroller in this case) configure the Si5135A at power up. .
Karl
It looks like the default configuration is a factory-only thing. The datasheet links to a program that generates a configuration spec and sends it to Silicon Labs for production.
Our breakout is designed to be a microcontroller peripheral rather than a microcontroller driver, so it probably wouldn't be a good choice as a boot-time crystal replacement.
karl_nottkarl
Thanks for looking into it. At the moment it's doing a good job of supporting one microcontroller running at 16Mhz and another at 8Mhz, with the breakout driven by a third.
Hey, as long as it works, you win! ;-)
jmg
Post by jmg »
karl_34 wrote: The one thing I did see in the datasheet which I couldn't find any further detail on was configuring the Si5135A's nvram to store a default configuration. Is that something that can only be done at factory time?
Yes, it is only factory Set, but there are some pre-configured part codes out there
If you drop this part code that is mentioned as one option in the Breakout BOM,
Si5351A-B02075-GT
into the Silabs partcode Lookup under Clocks.
http://www.silabs.com/products/clocksos ... -B02075-GT
you can get this Config file below, and also addendum link has Si5351A-B02075-GT_datasheet_addendum.pdf
which is a shorter PDF version of the Config file below.
: 27MHz -> 24.576 or when corrected for the 25MHz Xtal,
24.576*25/27 = 22.7555555MHz
Even if you buy a pre-config device, there is a risk if you reconfig over i2c from the MCU, as reset and PLL lock will interrupt the clock out, and any program error will remove the CLKOUT, or move it 'out of spec'.
It would be nice if Silabs had made the option of locking one VCO/PLL/Divider for MCU use.
# Do not modify the contents of this file.
# This file is for factory NVM programming.
#BEGIN_PROFILE
# Name: 1
#Profile = 1
#BEGIN_HEADER
# Date = Thursday, February 21, 2013 21:38
# File version = NVM 3
# Software Name = ClockBuilder Desktop Software
# Software version = 6.0.0
# Software date = December 13, 2012
# Chip = Si5351A
# Part Number = Si5351A-x-GT
#END_HEADER
# I2C address = 0x6F
#XTAL (MHz) = 27.000000000
#Mode = Automatic
#PLL A
# Input Frequency (MHz) = 27.000000000
# F divider = 1
# PFD (MHz) = 27.000000000
# VCO Frequency (MHz) =  737.280000000
# Feedback Divider = 27  23/75
# Internal Load Cap (pf) = 10
# SSC disabled
#PLL B
# Input Frequency (MHz) = 0.0
# VCO Frequency (MHz) =  0.0
# Pull Range (ppm) = 0.0
#Output Clocks
#Channel 0
# Output Frequency (MHz) = 24.576000000
# Multisynth Divider = 30
# R Divider = 1
# PLL source = PLLA
# Initial phase offset (ns) = 0.000
# Error (ppm) = 0.0000
# Powered = On
# Inverted = No
# Drive Strength (mA) = 8
# Disable State = Low
#Channel 1
# Powered = Off
#Channel 2
# Powered = Off
#Channel 3
# Powered = Off
#Channel 4
# Powered = Off
#Channel 5
# Powered = Off
#Channel 6
# Powered = Off
#Channel 7
# Powered = Off
#REGISTER_MAP
  0,00h
  1,00h
  2,18h
  3,00h
  4,00h
  5,FFh
  6,00h
  7,F0h
  8,00h
  9,00h
 10,00h
 11,00h
 12,00h
 13,00h
 14,00h
 15,00h
 16,4Fh
 17,80h
 18,80h
 19,80h
 20,80h
 21,80h
 22,80h
 23,80h
 24,00h
 25,00h
 26,00h
 27,4Bh
 28,00h
 29,0Bh
 30,A7h
 31,00h
 32,00h
 33,13h
 34,00h
 35,00h
 36,00h
 37,00h
 38,00h
 39,00h
 40,00h
 41,00h
 42,00h
 43,01h
 44,00h
 45,0Dh
 46,00h
 47,00h
 48,00h
 49,00h
 50,00h
 51,00h
 52,00h
 53,00h
 54,00h
 55,00h
 56,00h
 57,00h
 58,00h
 59,00h
 60,00h
 61,00h
 62,00h
 63,00h
 64,00h
 65,00h
 66,00h
 67,00h
 68,00h
 69,00h
 70,00h
 71,00h
 72,00h
 73,00h
 74,00h
 75,00h
 76,00h
 77,00h
 78,00h
 79,00h
 80,00h
 81,00h
 82,00h
 83,00h
 84,00h
 85,00h
 86,00h
 87,00h
 88,00h
 89,00h
 90,00h
 91,00h
 92,00h
 93,00h
 94,00h
 95,00h
 96,00h
 97,00h
 98,00h
 99,00h
100,00h
101,00h
102,00h
103,00h
104,00h
105,00h
106,00h
107,00h
108,00h
109,00h
110,00h
111,00h
112,00h
113,00h
114,00h
115,00h
116,00h
117,00h
118,00h
119,00h
120,00h
121,00h
122,00h
123,00h
124,00h
125,00h
126,00h
127,00h
128,00h
129,00h
130,00h
131,00h
132,00h
133,00h
134,00h
135,00h
136,00h
137,00h
138,00h
139,00h
140,00h
141,00h
142,00h
143,00h
144,00h
145,00h
146,00h
147,00h
148,00h
149,00h
150,00h
151,00h
152,00h
153,00h
154,00h
155,00h
156,00h
157,00h
158,00h
159,00h
160,00h
161,00h
162,00h
163,00h
164,00h
165,00h
166,00h
167,00h
168,00h
169,00h
170,00h
171,00h
172,00h
173,00h
174,00h
175,00h
176,00h
177,00h
178,00h
179,00h
180,00h
181,30h
182,00h
183,D2h
184,60h
185,60h
186,00h
187,C0h
188,00h
189,00h
190,00h
191,00h
192,00h
193,00h
194,00h
195,00h
196,00h
197,00h
198,00h
199,00h
200,00h
201,00h
202,00h
203,00h
204,00h
205,00h
206,00h
207,00h
208,00h
209,00h
210,00h
211,00h
212,00h
213,00h
214,00h
215,00h
216,00h
217,00h
218,00h
219,00h
220,00h
221,0Dh
222,00h
223,00h
224,00h
225,00h
226,00h
227,00h
228,00h
229,00h
230,00h
231,00h
232,00h
#END_REGISTER_MAP
#END_PROFILE
# CHECKSUM = EB8087DB9297BE82D2CD262B19E83CE135CB6D79
