hi,
Adafruit PN532 RFID/NFC Breakout isn't working!
I tried the examples and re-checked the wiring many many times still the same results (Hello! Didn't find PN53x board)
checked sel0 and sel1 for SPI many times also,
i think something's wrong with it and i don't know what to do
thank you
- adafruit_support_rick
Re: Adafruit PN532 RFID/NFC Breakout
Please post clear, detailed pictures of both sides of the board, showing your soldering.
I checked for short-circuit between the pins
- Screenshot_2014-10-18-10-42-02[1].png (820.12 KiB) Viewed 358 times
- Screenshot_2014-10-18-10-37-08[1].png (1012.1 KiB) Viewed 358 times
- Screenshot_2014-10-18-10-30-03[1].png (827.33 KiB) Viewed 358 times
That looks good. Can you post a picture of how you have it wired to the Arduino?
It won't be clear, I wired it as here https://learn.adafruit.com/adafruit-pn5 ... out-wiring
Arduino digital pin 2 is connected to 4050 pin 9
Arduino digital pin 3 is connected to 4050 pin 11
Arduino digital pin 4 is connected to 4050 pin 14
On the breakout board
3.3Vin is connected to the Arduino 3.3V pin
SCK is connected to 4050 pin 10
MISO is connected to Arduino pin 5
MOSI is connected to 4050 pin 12 (yellow wire)
SSEL is connected to 4050 pin 15& (green wire)
GND connects to Arduino ground (black wire)
Also connect 4050 pin #1 to 3.3V and pin #8 to ground.
I re-did the wiring many times
I bought also wifi cc3000 and it's working amazingly well
- 20141021_062345[1].jpg (105.43 KiB) Viewed 339 times
- 20141021_062349[1].jpg (97.84 KiB) Viewed 339 times
- 20141021_062429[1].jpg (103.76 KiB) Viewed 339 times
also a photo of the wiring
- 20141021_062334[1].jpg (110.56 KiB) Viewed 339 times
Let's try replacing it. Please email [email protected] with a link to this thread for a replacement PN532 breakout
Thank you for your support and thank you for you time trying to help me
also thank you for your fast response to my issue
You're welcome!
