Hi there,
Just recently received a PowerBoost 500 Basic to do some tests with and unfortunately it looks like I fried it right away, just not sure why.
I have a simple project that is powering a 1m strip of NeoPixels RGB LEDs (30) from a Teensy 3.1 using a 74HCT245 chip to boost the data signal from the Teensy to the LED strip. The project works just fine on USB power from the computer to the Teensy.
As a quick test, to hookup the power boost, I used a single battery holder and connected the + to the BAT pin and the - to the GRD pin, then ran a USB cable from the powerboost to the Teensy. Worked for about 3 seconds and then had a small pop and some smoke and the powerboost appears to be out of commission (with a red led lit). At this point just hooking the battery to the powerboost, the powerboost almost immediately gets very hot.
I am using a UltaFire LC 14500 1200mAh 3.7v battery as the power source.
Was the draw of the 1m LED strip to much for the powerboost, is this the wrong type of battery, or is something else going on here?
Thank you for your help!
PowerBoost 500 Basic - smoking hot?
Re: PowerBoost 500 Basic - smoking hot?
At full intensity, the strip will want to draw about 1.8 Amps. But a typical light pattern like the strandtest demo will pull less than 1/2 that. The PowerBoost 500 should give you up to 1A from a 3.7v source, so it should be able to handle the strip in typical use.
Does the Teensy w/strip still function on USB? Most computer USB ports are limited to 500mA.
- bwalls040971
yes, the Teensy and the strip still work just fine on computer/USB power. Looks like just an issue with the powerboost.
- bwalls040971
BTW- I do have a Powerboost 500 Charger unopened here I can test with as well, I just want to make sure I am not doing something else wrong first to avoid loosing that one as well.
Sounds like a problem with the PowerBoost. If it were a short in the load, it wouldn't run from USB either. Please contact [email protected] with a link to this thread for a replacement.
- bwalls040971
Will do. It worked just fine with the other one, so I guess that was all that it was.
Thank you for all the help :-)
- adafruit2
yah sounds like you may have had too much current, try lowering the current draw, make sure your wires are not too long going into the power boost pcb from the battery, try to have it < 3"bwalls040971 wrote:Hi there,
