GEMMA ROUND 2
bropium
GEMMA ROUND 2
Post by bropium »
My apologies for my previous post. After not getting any responses, I looked up the proper way to post for best answers (http://forums.adafruit.com/viewtopic.php?f=25&t=12170 - for those who don't know).
So here goes my third post.
I am working the DIY FLIR Light Painting - Heat Map Photography (https://learn.adafruit.com/diy-flir-lig ... y?view=all). I am not making the gun, but just using the temperature sensor and lights for a different project.
The problem that I am having is getting the lights to change from blue to red due to temperature. The NeoPixel Ring lights up with which ever color I put as the lowest temperature. For example:
The ring lights up as blue when -
#define COLDTEMP 60
#define HOTTEMP 80
But it lights up as red when -
#define COLDTEMP 80
#define HOTTEMP 60
I know the temperature sensor works because I tested it with the "Using Melexis MLX90614 Non-Contact Sensors" (https://learn.adafruit.com/using-melexi ... g-and-test).
I am positive that my wiring is correct, and that GEMMA is set-up properly. I followed the "Introducing GEMMA" guide (https://learn.adafruit.com/introducing-gemma).
The last thing to check is the code, which I have the least experience with. I did swap out the 24x NeoPixel Ring for the 12x NeoPixel Ring, but other than that, I followed the guide as written.
This is a library for the MLX90614 temperature sensor SPECIFICALLY
FOR USE WITH TINYWIREM ON TRINKET/GEMMA
Requires the latest TinyWireM with repeated-start support
https://github.com/adafruit/TinyWireM
NOT FOR REGULAR ARDUINOS! Use the regular Adafruit_MLX90614 for that
  Designed specifically to work with the MLX90614 sensors in the
  adafruit shop
  ----> https://www.adafruit.com/products/1748
  ----> https://www.adafruit.com/products/1749
  These sensors use I2C to communicate, 2 pins are required to
  interface
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit in any redistribution
#include <TinyWireM.h>
#include <Adafruit_MiniMLX90614.h>
// change these to adjust the range of temperatures you want to measure
// (these are in Farenheit)
#define COLDTEMP 60
#define HOTTEMP  80
#define PIN 1
Adafruit_NeoPixel strip = Adafruit_NeoPixel(24, PIN, NEO_GRB + NEO_KHZ800);
Adafruit_MiniMLX90614 mlx = Adafruit_MiniMLX90614();
  mlx.begin();
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  uint8_t red, blue;
  float temp = mlx.readObjectTempF();
  if (temp < COLDTEMP) temp = COLDTEMP;
  if (temp > HOTTEMP) temp = HOTTEMP;
  // map temperature to red/blue color
  // hotter temp -> more red
  red = map(temp, COLDTEMP, HOTTEMP, 0, 255);
  // hotter temp -> less blue
  blue = map(temp, COLDTEMP, HOTTEMP, 255, 0);
  colorWipe(strip.Color(red, 0, blue), 0);
  delay(50); // can adjust this for faster/slower updates
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, c);
      strip.show();
      delay(wait);
Thanks for the help!
adafruit_support_mike
Re: GEMMA ROUND 2
What value are you getting from this line?
bropium
Re: GEMMA ROUND 2
Post by bropium »
Do I just upload that code onto GEMMA and it will display a value?
Re: GEMMA ROUND 2
That line is already in your sketch.
The Trinket and Gemma can't do Serial output to the computer, so you'll have to find some other way to display the information.
Try this:
    int i=0;
    float t = temp;
    while ( t > 0 ) {
        strip.setPixelColor( i, strip.color( 100, 100, 100 ) );
        i++;
        t -= 10;
    strip.show();
    delay( 2000 );
That will light one pixel for every 10 degrees of the temperature reading, giving you at least a general idea of the value.
