Ive just hooked up the lcd backpack as shown, terminal block side is pin 1 through to pin 14
Pin15-18 are wired separately and i can control backlight quite easily.
But the screen just displays these boxes, i can get them to go away by using the contrast knob but then its just a blank screen. And cant get anything else up.
I have tried the adafruit liqidcrystal i2c hello world as well as the liquidcrystaltwi by falconfour and both have the same outcome.
I have resoldered all pins and have de-soldered and re-soldered. Double checked the pin layouts. And now im lost. Does anyone have any ideas?
I have hooked it up to both a mega and an uno, dat to pin 20 & clk to 21 and a4 & a5 respectively.
Im hoping its just too late at night and I need a fresh approach. Can anyone provide that fresh set of eyes.
LCD Backpack + 20x4 rgb lcd not working??
- Eha002
- Attachments
- image.jpg (117.03 KiB) Viewed 295 times
- image.jpg (177.13 KiB) Viewed 295 times
- image.jpg (250.91 KiB) Viewed 295 times
Re: LCD Backpack + 20x4 rgb lcd not working??
The soldering and connections look OK. Are you using stranded wire? This can be a problem in headers sometimes. Better to solder it to a pin or a short piece of solid-core.
- Eha002
Yes it is stranded. With the ends tinned. But ill try with a pin soldered to each end and report back.
So the pin orientation seems correct?
Sorry for duplicate post,
The website said something along the lines of you do not have permission to view this page, when i pressed submit so i figured it failed to upload.
Yes, the pin orientation looks right. Usually we solder them from the back-side, but as long as pin 1 is positioned at the end with the terminal blocks, you should be OK.
