PowerBoost 500 Charger LEDs
Pnuewm
Post by Pnuewm »
I've been looking at the PowerBoost 500 Charger and Shield and one the features I like the most are the LED indicators. I'd like to use a PowerBoost in my project, but I'm going to put it inside of an enclosure and so the LEDs won't be visible. The best idea I can come up with is to remove the LEDs that are already there and replace them each with a 5mm LED. I was wondering if there was any better option or if my idea is acceptable.
adafruit_support_mike
Re: PowerBoost 500 Charger LEDs
You can wire LEDs to the breakout holes along the side of the PCB.
The green power-status LED is connected to the 5v pin. The red low-battery-status LED is connected to the LBO pin.
Pnuewm
Post by Pnuewm »
I didn't notice that. What about the "Charging" and "Fully Charged" LEDs? I see that there aren't any breakout holes for those two.
I'm afraid those aren't broken out.
They're both controlled by a single pin on the MCP73831, and you can solder a tap in at any (or all) of these three points:
A 30 gauge wire across the ends of the resistors shouldn't be too hard to solder, and will give you a strong connection.
Once you have the jumper, connect a yellow or orange LED to VCC and a 470 ohm resistor, and a green LED to GND and a 1k resistor. Connect the free ends of both resistors to the tap from the PCB.
Pnuewm
Post by Pnuewm »
Thanks, that's a good idea. I can do the same thing for the Shield version, correct?
Yep. The resistors and LEDs are arranged differently, but the same idea applies.
For the shield you'd connect the tap between the resistors:
Pnuewm
Post by Pnuewm »
The shield version doesn't breakout the 5V or LBO pins, right? I should be able to solder a tap onto each LED's resistor, correct?
That's right, the signal that controls the status LEDs isn't broken out.
A tap to the point between the two resistors will give you the signal you need.
Pnuewm
Post by Pnuewm »
I think that answers all my questions. Thank you for your help.
