There is an error in the low-side sensing picture at
https://www.adafruit.com/product/574
It refers to "thick" and "thin" wires. So far, so good. The the circuit shows the thick black wire going to the power source, and the nonexistent thick red wire connected to the load. As I needed to know how to really hook it up correctly, I wondered if the black wire in the picture was the black wire on the meter. A bit of experimentation with a 5V power supply and a 47 ohm resistor showed me that the correct wiring was white-to-power, black-to-load. The opposite arrangement gave a 0 current reading.
It might be nice to redo the figure so it matches the reality.
joe
Error in picture
- adafruit_support_rick
Re: Error in picture
Thanks! I'll check it out
- adafruit2
hiya the manufacture changed the thick wires to white instead of red, which is good :) the product text is updated
