I have a rather idiotic newbie question.
I'm getting a fobkey read from an rfid reader i got a while back. It's coming in as ASCII hex i believe and on the pi using python i'd like to convert it to the actual key that is written on the fob.
so from
"0C0032667C24" to 0003303036 which is written the fob.
I feel like an idiot but i've tried in ipython everything to convert the ASCII/hex to that digit and nada.
Also i think the last two ASCII characters are checksum keys it's a 125khz rfid reader which doesn't seem to be sold on adafruit anymore though..
so i think checksum is 24
any help much appreciated for python help.
fob key conversion
- adafruit_support_rick
Re: fob key conversion
"0C0032667C24" is hex. Not sure what the 0c is, but I'll guess it's the total length of the string. 24 does appear to be some sort of checksum. So that leaves you with 0032667C hex, which is ...wait for it... 3303036 decimal!
- prussia
hmm thanks for the reply but I sort of stated all that in my post already? I was trying to get help with the python part but I think I figured it out after my post. All but how to use checksum to test
fob_decimal = int(fob[2:10],16)
str(fob_decimal)
Sorry. I misunderstood the question.
The checksum looks like the accumulated XOR of the message bytes, including the 0C. At least, 0C ^ 00 ^ 32 ^ 66 ^ 7C is 24.
- prussia
he he,
No problem. so i'm trying to write something in ipython to test the xor but i have no idea how i'd convert the fob string. add the 0x then XOR. seems in python I have to run:
to get 0x24 out (checksum) but not sure how to compose the above. nudge, hint or sample code would be nice :)
hex(0x0C ^ 0x00 ^ 0x32 ^ 0x66 ^ 0x7C)
I'm definitely not the guy to ask about python, but I think you'd do something like
That includes the checksum in the calculation, so the result should always be zero if you have a valid string.
Of course, you might want to code this up as a loop, if your strings can change in length.
check = int(fob[0:1],16) ^ int(fob[2:3],16) ^ int(fob[4:5],16) ^ int(fob[6:7],16) ^ int(fob[8:9],16) ^ int(fob[10:11],16)
- prussia
hmm,
yeah I tried that but seems i need the 0x part too. not sure.
