I will use BMP183 (Adafruit BMP183 SPI Barometric Pressure & Altitude Sensor) to measure pressure of biogas which contains about 1% H2S (hydrogen sulphide) and is saturated with humidity.
I will cover rest of the PCB with silicone for protection and sealing. But, I want actual sensor to be not covered for obvious reasons.
Is the sensor resistant to H2S corrosion?
Thanks in advance.
corrosion resistance of BMP183
- adafruit_support_rick
Re: corrosion resistance of BMP183
Sorry, but we have no idea about that. We've never tested it under those conditions, and the datasheet doesn't mention anything of the kind.
- ecomod
Thanks anyway, for your reply.
