I get video from this adapter fine. But the main reason i purchased this device
is to split off the audio of my Windows 7 laptop to my sound board. I hear
video audio faintly, but mostly just electronic hum, even after using a
direct box with ground lift (lowers hum, but audio is still faint). I'm
going out of the audio output of the #1151 adapter to a quarter inch adapter
cable into a direct box to an XLR cable run of 40 feet back to the sound
board. I checked all my cables and they work fine. I also made sure
playback on the audio of my laptop was from the projector setting.
Audio problem with HDMI to VGA ADAPTER with audio output #11
- tdwight1
- adafruit2
Re: Audio problem with HDMI to VGA ADAPTER with audio output
for sanity, try headphones to start :)
next up, in windows, you can adjust the volume of Playback Devices, does that help?
- Defaultnotice
I have the same noise problem. I tried headphones as well as my regular receiver. All I could ever get was a high pitched hum like there was some interference in the line.
