I just purchased the NFC/RFID shield along with some other components.
When I set up the NFC shield today, I tried to test it using the card that came with it.
Unfortunately I have been getting some errors.
I firstly formatted the card using the default formatndef Sketch, with the default adafruit.com URL
This seemed to work fine.
Looking for PN532...
Found chip PN532
Firmware ver. 1.6
PLEASE NOTE: Formatting your card for NDEF records will change the
authentication keys. To reformat your NDEF tag as a clean Mifare
Classic tag, use the mifareclassic_ndeftoclassic example!
Place your Mifare Classic card on the reader to format with NDEF
and press any key to continue ...
Found an ISO14443A card
UID Length: 4 bytes
UID Value: 0x50 0x6B 0x56 0x0B
Seems to be a Mifare Classic card (4 byte UID)
Card has been formatted for NDEF data using MAD1
Writing URI to sector 1 as an NDEF Message
NDEF URI Record written to sector 1
Done!
using the stock memdump sketch i get the following errors:
Found chip PN532
Firmware ver. 1.6
Waiting for an ISO14443A Card ...
UID Length: 4 bytes
------------------------Sector 0-------------------------
Block 0 50 6B 56 0B 66 88 04 00 00 00 00 00 00 00 00 00 BANNED.f..........
Block 1 14 01 03 E1 03 E1 03 E1 03 E1 03 E1 03 E1 03 E1 ...á.á.á.á.á.á.á
Block 2 03 E1 03 E1 03 E1 03 E1 03 E1 03 E1 03 E1 03 E1 .á.á.á.á.á.á.á.á
Block 3 00 00 00 00 00 00 78 77 88 C1 00 00 00 00 00 00 ......xwÁ......
------------------------Sector 1-------------------------
Block 4 00 00 03 11 D1 01 0D 55 01 61 64 61 66 72 75 69 ....Ñ..U.adafrui
Block 5 74 2E 63 6F 6D FE 00 00 00 00 00 00 00 00 00 00 t.comþ..........
Block 6 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Block 7 00 00 00 00 00 00 7F 07 88 40 00 00 00 00 00 00 .......@......
------------------------Sector 2-------------------------
Block 8 unable to read this block
Block 9 unable to read this block
Block 10 unable to read this block
Block 11 unable to read this block
------------------------Sector 3-------------------------
Authentication error
Block 12 unable to authenticate
Block 13 unable to authenticate
Block 14 unable to authenticate
Block 15 unable to authenticate
------------------------Sector 4-------------------------
Block 16 unable to authenticate
Block 17 unable to authenticate
Block 18 unable to authenticate
Block 19 unable to authenticate
------------------------Sector 5-------------------------
Block 20 unable to authenticate
Block 21 unable to authenticate
Block 22 unable to authenticate
Block 23 unable to authenticate
------------------------Sector 6-------------------------
Block 24 unable to authenticate
Block 25 unable to authenticate
Block 26 unable to authenticate
Block 27 unable to authenticate
------------------------Sector 7-------------------------
Block 28 unable to authenticate
Block 29 unable to authenticate
Block 30 unable to authenticate
Block 31 unable to authenticate
------------------------Sector 8-------------------------
Block 32 unable to authenticate
Block 33 unable to authenticate
Block 34 unable to authenticate
Block 35 unable to authenticate
------------------------Sector 9-------------------------
Block 36 unable to authenticate
Block 37 unable to authenticate
Block 38 unable to authenticate
Block 39 unable to authenticate
------------------------Sector 10-------------------------
Block 40 unable to authenticate
Block 41 unable to authenticate
Block 42 unable to authenticate
Block 43 unable to authenticate
------------------------Sector 11-------------------------
Block 44 unable to authenticate
Block 45 unable to authenticate
Block 46 unable to authenticate
Block 47 unable to authenticate
------------------------Sector 12-------------------------
Block 48 unable to authenticate
Block 49 unable to authenticate
Block 50 unable to authenticate
Block 51 unable to authenticate
------------------------Sector 13-------------------------
Block 52 unable to authenticate
Block 53 unable to authenticate
Block 54 unable to authenticate
Block 55 unable to authenticate
------------------------Sector 14-------------------------
Block 56 unable to authenticate
Block 57 unable to authenticate
Block 58 unable to authenticate
Block 59 unable to authenticate
------------------------Sector 15-------------------------
Block 60 unable to authenticate
Block 61 unable to authenticate
Block 62 unable to authenticate
Block 63 unable to authenticate
Send a character to run the mem dumper again!
Found chip PN532
Firmware ver. 1.6
UID Length: 4 bytes
Trying to authenticate block 4 with default KEYA value
Ooops ... authentication failed: Try another key?
UID Length: 4 bytes
Found chip PN532
Firmware ver. 1.6
Place your NDEF formatted Mifare Classic 1K card on the reader
Found an ISO14443A card/tag
UID Length: 4 bytes
Reformatting card for Mifare Classic (please don't touch it!) ...
Authentication failed for sector 16
It is equally if not more likely however that I am making a mistake somewhere along the line so please point me in the right direction if that is the case.
Thanks for your help,
Cathal.
