12 Key Capacitive Touch board interfering with servo
tdicola
Re: 12 Key Capacitive Touch board interfering with servo
Post by tdicola »
Hrm, I just tried both an Uno and Leonardo (same processor as the Micro) and couldn't reproduce any jittering or issues with the MPR121. My setup was a servo on pin 9 and the MPR121 on the I2C bus pins. I put together both the servo sweep example and MPR121 test example to make a program that sweeps the servo and reads inputs. You can see the code below:
#include <Servo.h>
#include <Wire.h>
#include "Adafruit_MPR121.h"
// You can have up to 4 on one i2c bus but one is enough for testing!
Adafruit_MPR121 cap = Adafruit_MPR121();
// Keeps track of the last pins touched
// so we know when buttons are 'released'
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
Servo myservo;  // create servo object to control a servo
                // twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  Serial.begin(9600);
  Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
  myservo.attach(9);
  // Default address is 0x5A, if tied to 3.3V its 0x5B
  // If tied to SDA its 0x5C and if SCL then 0x5D
  if (!cap.begin(0x5A)) {
    Serial.println("MPR121 not found, check wiring?");
    while (1);
  Serial.println("MPR121 found!");
void checkTouches() {
  // Get the currently touched pads
  currtouched = cap.touched();
  for (uint8_t i=0; i<12; i++) {
    // it if *is* touched and *wasnt* touched before, alert!
    if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" touched");
    // if it *was* touched and now *isnt*, alert!
    if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
      Serial.print(i); Serial.println(" released");
  // reset our state
  lasttouched = currtouched;
  for(pos = 0; pos <= 180; pos += 1) // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
    checkTouches();
  for(pos = 180; pos>=0; pos-=1)     // goes from 180 degrees to 0 degrees
    checkTouches();
It's odd if you're seeing jittering, since like Bill mentioned the MPR library just uses I2C to communicate with the device and shouldn't the timers at all. I wonder if something else like perhaps another library is being included and accidentally messing with the servo PWM timers. If you take my sketch above and connect a servo signal pin to pin 9 on the board and the MPR121 to the I2C pins do you see the same jittering issues?
The other possibility is that the servos are picking up noise from the cap-touch board. Make sure that your servo wiring is routed well away from the cap touch.
