in the product description for the nema 17 stepper, it says you used a motor shield and got it running at some 250 rpm. mine doesn't seem to run nearly this fast even with rpm set at 250 in the test sketch...
how fast can it actually go? what's fastest, double, single interleaved?
i don't need that much torque, but i need a lot more speed than what i'm getting or i have to find another kind of motor. there's literally no dc motor out there i've found that has a direct drive 5mm shaft, attaching stuff to the <2mm ones sucks horribly.
stepper speed?
- Franklin97355
Re: stepper speed?
What code are you running and how fast do you need the motor to run? Also how are you measuring the speed of your motor?
- mrniss
Re: stepper speed?
stopwatch. it's not exactly accurate, but it's somewhere between 50-60 roughly.
project is basically a 3 foot linear actuator, but with the stepper it takes about 10 years to get from one side to the other at this speed.
i was trying to not spend 400 dollars to make a stupid two axis travelling platform, but apparently it's impossible to do without all these belts pulleys tracks bearings kill me
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
int dir;
AFMS.begin(); // create with the default frequency 1.6KHz
myMotor->setSpeed(250); // 10 rpm
myMotor->step(40, FORWARD, DOUBLE);
Re: stepper speed?
At that speed with those motors you are pushing the limits of the i2c bus throughput. It is possible to get to 250 RPM with some optimizations. See this thread for details: http://forums.adafruit.com/viewtopic.ph ... 1&p=292119
