Powerboost 500C and Terminal Block?
- CodyTheodore
Hello, I need to know if it is ok to use the Powerboost 500C and a terminal block to hook up to a lightning connector (only the + and - pins) to charge an iPhone? or does the iPhone need to be hooked up to the data pins for some reason? Thanks!
- Franklin97355
Re: Powerboost 500C and Terminal Block?
Most iphones use some form of negotiation on the data pins for selecting a valid charger.
The Lightning connector is even more complicated.. the pins can be dynamically reassigned to carry power or signals, and contain an ID chip that the device polls:
http://en.wikipedia.org/wiki/Lightning_(connector)
