Pins for Real TIme Clock
jeff009
Post by jeff009 »
I'm working on a project which is using the DS1307 Real Time Clock breakout board kit. I have the SDA hooked up to Analog 4, and SCL hooked up to Analog 5 (just like the instructions state), and it's working fine with my Uno.
My question though, is what if I'm using it with a board which doesn't have A4 and A5, but does have A0 and A1... what sets the RTC to use A4 and A5? I've been reading over RTCLib.cpp and RTClib.h and I don't see how it's being set up to use those pins. Is it possible to set the RTC library to use A0 and A1 instead?
Thanks,
Jeff
Franklin97355
Re: Pins for Real TIme Clock
Post by Franklin97355 »
The clock uses i2c and the Uno brings that out on pins A4 and A5. You need to connect the board to whatever pins on your device communicate with i2c. On some devices you can use any two pins, others have dedicated pins.
