ST7565 Font
mOSKit
ST7565 Font
Post by mOSKit »
Hi, can you please tell me how to set different font and size? if style is not available than changing the size would be enough for me.
Thank you
Re: ST7565 Font
There is no 'native' font for these displays. So it is built into the library. https://github.com/adafruit/ST7565-LCD/ ... glcdfont.c
It is an 8x5 pixel font. To change it would require some library hacking.
mOSKit
Re: ST7565 Font
Post by mOSKit »
So if i generate new hex file say with some font generator would that work?
Neved done such thing
Re: ST7565 Font
Yes. If the font generator can do 8x5 it should work with the existing code. Otherwise, you would need to hack the drawchar method:
void  ST7565::drawchar(uint8_t x, uint8_t line, char c) {
  for (uint8_t i =0; i<5; i++ ) {
    st7565_buffer[x + (line*128) ] = pgm_read_byte(font+(c*5)+i);
    x++;
  updateBoundingBox(x, line*8, x+5, line*8 + 8);
