Trouble connecting the LG LP097QX1
- Chris_TCN
I have a problem connecting the LG LP097QX1 to the Qualia Bare Driver Board. The cable coming from the display panel seems to wide to fit in. Is there some kind of trick?
- adafruit_support_rick
Re: Trouble connecting the LG LP097QX1
Did you release the connector socket? I believe it flips up.
- Chris_TCN
Yes, its flipped up but the cable still doesn't fit in.
- adafruit2
nothing's changed and we use the same connectors for the full kit, if you want you can post up a photo and we'll take a look
- Chris_TCN
Here's an image of the connection.
Meanwhile I managed to break the socket while trying to connect it.
Thanks, we have special note regarding something like this on the product page.
This driver is available for advanced users only! The Molex connector that is used to connect to the LG display is insanely delicate and breaks very very very easily if you are not very careful! If you order this driver board and break the connector, it may no longer work and we cannot repair it. If you break it you may have to buy another driver. We do not offer any returns, refunds or replacements! Do not purchase if you are not comfortable with this risk!
https://www.adafruit.com/products/1716
Thanks,
Adafruit Support
Thanks,
Adafruit Support
- jernejj
Hello everyone!
I have troubles with product ID 1716
Display that I have is LG LP097QX1, I have power adapter of 12V 1A, and Displayport-displayport cable. But I cant get picture out of it. It is also detected on a computer, but I can not get picture out. Can you please help me,? Do i need any specific drivers, I updated all mine (radeon R9 200 series). I am using win 8.1 64bit
Regards Jernej
Regards Jernej
- Attachments
- pic3.jpg (194.24 KiB) Viewed 401 times
- pic2.jpg (449.39 KiB) Viewed 401 times
- Detection of a new display
- pic1.JPG (51.17 KiB) Viewed 401 times
- adafruit2
the molex connector is not locked down, it should be CAREFULLY pressed down amd locked into place
- jernejj
Is that what you mean, that black connector needs to be in place, turned to the left gently?
- Attachments
- pic4.jpg (131.54 KiB) Viewed 389 times
- jernejj
Done that, still same picture. White screen, it is detected but no windows picture. Does the white part of connector also move? Do you have maybe a good picture how far needs to be connector inserted?
Best regards!
Best regards!
- Attachments
- pic5.jpg (84.46 KiB) Viewed 386 times
- adafruit2
Try it with a Mac that way you know if its your displayport adapter?
- jernejj
The only thing I didnt try is with different computer. Need to try that also, then we shall see.
Thank you so far!
Thank you so far!
- BILBO
Hello everyone!
I have troubles with Order Confirmation No: 1147736-8140918626 and 1147735-3659616954 (Retina Display (LP097QX1) and two Qualia Bare Driver Boards).
Both Qualia Bare driver boards are tested alternately with a MacBook and Windows 7 computer. The Retina Display has been connected to the Qualia Bare Driver Board (cable are plugged in and the plastic clasp on the ribbon is pushed down). I have power adapter of 12V 5A and Displayport-cable. But I cant get picture out of it. I can see only a white picture on the Retina Display. Both computers cant detect the Retina Display (LP097QX1).
Do you have an idea how to fix the problem?
- BILBO
I found the problem. We ordered the Retina Display (LP097QX1) (Order Confirmation No: 1147735-3659616954) but shipped was the Samsung Display (LTL097QL01-W01).
The pin assignment of the display is different. Can we change the Samsung Display (LTL097QL01-W01) to the Retina Display (LP097QX1)?
- Franklin97355
Please contact [email protected] with a link to this thread and your order details and they will help you
