- Capture2.JPG (28.14 KiB) Viewed 302 times
Thanks for your time, I have 2 questions.
1. Can (and if so, how) the Rpi generate a wifi network and connect to a different wifi network at the same time? (using 2 wifi dongles and essentially replacing eth0 with a wifi connection, although I would like to have it wired most of the time but be able to disconnect wired internet and switch to wifi.)
Note: I momentarily only have access to the web through wifi, I use a second dongle on wlan1 during the tutorial.
2. I cannot seem to get dhcp server to run reliably, when I run
sudo service isc-dhcp-server start
I receive this error message:
- Capture1.JPG (14.08 KiB) Viewed 302 times
I found this when I ran tail -f /var/log/syslog
- Capture.JPG (42.83 KiB) Viewed 302 times
When I couldn't get the access point working I went through all the steps in the tutorial (except for the hostapd steps, because that seemed to be working) and dhcp server magically came to life! I never found any errors in the code, I just checked the code and re-ran commands.
Any help is appreciated!
