I just discovered that using the AR1100 calibration software in a NORMAL manner will result in a partially* bricked device. Here is what NOT to do:
0. connect AR1100 USB adapter
1. start calibration software
2. choose Communications Mode -> Digitizer
3. click Verify Communication
While it will continue to work as a digitizer, it is now no longer possible to run the configuration utility or change modes.
From this point on, the device will enumerate as "Digitizer", regardless of what setting is selected.
Note that the Adafruit documentation states:
But unfortunately this is not true.This is kind of the fix-all button if you ever find you got the AR1100 in a weird mode.
If anyone has tips on how to get the AR1100 working again (meaning "able to communicate with the configuration utility"), please let me know.
This was done on a recent x86-64 machine running Windows 8.1
Here's the log output:
3:05:11 PM Welcome to the Microchip AR Configuration Utility version 2.20
3:05:11 PM Wizard opened . . .
3:05:13 PM Wizard set dev kit type to custom
3:05:15 PM Wizard set number of touch sensor wires to 4
3:05:17 PM Wizard set device type to 1100
3:05:19 PM Wizard set protocol to USB Mouse
3:05:21 PM Wizard set protocol to USB Mouse
3:05:21 PM Wizard set protocol to USB Digitizer
3:05:24 PM Found Tub.dll - Ver: 1.5.0.0
3:05:24 PM Error: Could not change mode to Digitizer. Verify the AR1100 is properly attached
3:05:28 PM Wizard set protocol to USB Digitizer
3:05:29 PM Wizard set protocol to USB Mouse
3:05:31 PM Found Tub.dll - Ver: 1.5.0.0
3:05:31 PM Error: Could not change mode to Mouse. Verify the AR1100 is properly attached
3:05:35 PM Found Tub.dll - Ver: 1.5.0.0
3:05:35 PM Error: Could not change mode to Mouse. Verify the AR1100 is properly attached
3:05:36 PM Wizard set protocol to USB Mouse
3:05:41 PM Wizard aborted . . .
3:05:41 PM Wizard aborted before communications established. Open the Options window from the Tools section of the ribbon to set communications mode.
3:05:50 PM Found Tub.dll - Ver: 1.5.0.0
3:05:50 PM Error: Could not change mode to Mouse. Verify the AR1100 is properly attached
3:06:01 PM Found Tub.dll - Ver: 1.5.0.0
3:06:01 PM Error: Could not change mode to HID. Verify the AR1100 is properly attached
3:06:06 PM USB AR1100 Digitizer Removed . .
3:06:27 PM USB AR1100 Digitizer Detected . .
3:06:30 PM Found Tub.dll - Ver: 1.5.0.0
3:06:30 PM USB AR1100 could not be found.
Please check your connections.
