I am attempting to use XBee adapters with a pair of XBee modules to do some tinkering. During the initial loopback testing I ran into an issue where the remote XBee didn't seem to be sending any signals back to the control module, despite having a jumper wire on the breadboard between the TX and RX breakout pins.
I was able to get the remote XBee to respond properly by putting a jumper on the TX and RX pins on the FTDI side of the adapter, which worked for that test, but I would like to determine why I might be having issues with the breadboard-side breakout pins.
XBEE Adapter Board TX/RX pins
- Franklin97355
Re: XBEE Adapter Board TX/RX pins
Could you post clear, detailed pictures of both sides of your board showing any soldering you have done and the connections to it?
- KehvAntile
I have six pictures of the board. Attached please find the first 3.
- Attachments
- Bottom of board
- Photo Feb 25, 9 57 47 AM.jpg (314.72 KiB) Viewed 198 times
- This does work using the RX and TX lines from the FTDI side of the adapter
- Photo Feb 25, 9 57 25 AM.jpg (304.54 KiB) Viewed 198 times
- This does not work despite connecting to the RX and TX pins (the other end of this is a Teensy acting as a USB To Serial converter)
- Photo Feb 25, 9 56 55 AM.jpg (314.59 KiB) Viewed 198 times
- KehvAntile
Here are the other 3. Please let me know if I need to try for other angles or better light.
Thank you
Thank you
- Attachments
- RX/TX closeup, board underside.
- Photo Feb 25, 9 49 06 AM.jpg (314.11 KiB) Viewed 198 times
- Breadboard pins side-view
- Photo Feb 25, 9 48 48 AM.jpg (220.23 KiB) Viewed 198 times
- Board bottom, alternate angle
- Photo Feb 25, 9 58 08 AM.jpg (222.61 KiB) Viewed 198 times
