Hi
Has the uv sensor a covering plastic, so that I can use it outside?
GUVA-S12SD
- adafruit_support_bill
Re: GUVA-S12SD
It does not come with any protective cover. If you plan to use it outside in an enclosure, be sure that any plastic or glass used in front of the sensor is not UV blocking.
