Can we get a better picture (or wiring diagram) of the demo setup of this device as seen in the new products video.
Many Thanks
IR Light Sensor 2349
- Franklin97355
Re: IR Light Sensor 2349
Found this with a Google search. http://sensing.honeywell.com/index.php?ci_id=50395 I don't have the part number on the Adafruit one but this should help.
[Moved from "Announcement" to "Other Adafruit Products"]
- tflora
Thanks for the Data Sheet but, Lady Ada's demo ( Wiring diagram & example code) from new products 2/11/2015 would help me out.
Great subject for the learning section.
- hamiltonharris
I bought one of these - but can't figure out how to make it work. Does anyone have a simple breadboard wiring example they can point me to?
- Franklin97355
Two pins are the led. wiring goes ground>pin, pin>resistor>power the other two pins go ground>pin, pin>Arduino input.
- hamiltonharris
Thanks. I managed to figure it out by using the camera on my IPAD2 to verify that the IR LED was on (looking through the camera it looks like a bright blue spot). Once that was working the rest was much easier.
- thelavajumper
yea im looking for the wiring diagram and sketch demo to test it out as well..tflora wrote:Thanks for the Data Sheet but, Lady Ada's demo ( Wiring diagram & example code) from new products 2/11/2015 would help me out.
