It is advertised that it can do 10Hz logging.
https://www.adafruit.com/product/746
But from following the gps install guide for a raspberry pi it seems to output 1Hz by default.
Can I increase the sampling rate?
Changing Ultimate GPS logging frequency
- Franklin97355
Re: Changing Ultimate GPS logging frequency
You can increase the sample rate by using the code in your program by adding the line
The #defines are in the Adafruit_GPS.h file:
// Set the update rate
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
#define PMTK_SET_NMEA_UPDATE_1HZ "$PMTK220,1000*1F"
#define PMTK_SET_NMEA_UPDATE_5HZ "$PMTK220,200*2C"
#define PMTK_SET_NMEA_UPDATE_10HZ "$PMTK220,100*2F"
- sqaure
This appears to be in C. The code posted here is in python:
https://learn.adafruit.com/adafruit-ult ... g-your-gps
