Hello. Using Adafruit MP3 shield. This is the non amp version.
I have a soldered connection from the Line Out +/- to an amp, however I am not getting any signal out. Works fine when using the headphone jack. The description says these can be used as line out, however I don't think it works without the amp build in. Am I incorrect? Is there a workaround. The solder joints are fine so its definitely not that.
Thank you
MP3 Shield to Amp - Line Out Issue
- Franklin97355
Re: MP3 Shield to Amp - Line Out Issue
Still if you could post pictures of your connections and the specs on the amp you are inputting to it would help.
- push8me
Solder has good contact all around. Picture was taken with phone, sorry for quality...
It works very well with the headphone connected to the amp.
Here is the amp: http://www.parts-express.com/6x100w-tda ... d--320-307
Is it possible that the there is no signal on the line out if the built in amp is not included?
Thanks for the help.
- mp3_shield
- mp3_shield.jpg (266.92 KiB) Viewed 231 times
- push8me
Also, if this will work without the built in amp, will these terminal blocks you sell fit the MP3 shield?
https://www.adafruit.com/products/724
- push8me
Pics of rca solder and rca connection
- Franklin97355
It looks like the terminal blocks are output from the amp only and you would have to create a cable that plugs into the headphone jack to get to the signal.
- push8me
Roger that. Bummer. Thank you for the info!
