Something seems to have happened when I tried to delete a couple files on my audio FX board. now when I mount the board on my mac it does not show a name and the files are corrupted. (see image)
I've tried to re-image the board but I get this error
When I try to rescan the .img file I get this error
Please advise.
Audio FX 16mb not mounting properly Mac
Re: Audio FX 16mb not mounting properly Mac
It looks like your disk image may have gotten corrupted.
Try downloading a fresh copy and see if that works.
- pgray23
I tried downloading another copy of the disk image. No luck, same thing.
- pgray23
some googling let me to this post
https://discussions.apple.com/thread/21 ... ID=2147658
I've followed those steps as well with no luck
Hrm.. let's do a quick check of data integrity.
Open Terminal, navigate to wherever you have the .zip and .img files stored, and enter:
assuming they're both in the same directory. If you have them in different directories, do them individually.
The hashes you get should be:
md5 SFX16mb.*
MD5 (SFX16mb.img) = dd1c643be700dca18c137db43f304e6b
MD5 (SFX16mb.zip) = 61455638d8deea1747a550973a040c38
- pgray23
Here's what I get:
MD5 (SFX16mb.img) = 01d3dcf0110fac93bc2bb3b4560f404f
- pgray23
Ok, I've found the solution. While in Disk Utility I first mounted the SFX16mb.img file and selected the mounted disc (white disc icon) as the source instead of the actual .img file. I was able to re-image the board and I'm back up and running.
Follow up question:
In my project I'm using the forground & backgound triggering as in the tutorial https://learn.adafruit.com/adafruit-aud ... triggering
is there any way to cycle through more than one file for the background file (named T10HOLDL.WAV) so that each time trigger 10 is triggered a different file will play? I tried naming the files T10HOLDL0.WAV T10HOLDL1.WAV but that didn't work.
Follow up question:
That would be the TnnNEXT.WAV trigger:
https://learn.adafruit.com/adafruit-aud ... er-dot-ogg
- pgray23
TnnNEXT.WAV doesnt allow me to interrupt the background sound with a forground sound. Using the TnnNEXT.WAV plays the entire file before another file can be played. is there a way to cycle through more than one TxxHOLDL.WAV?
Not on a single pin.
You could set up multiple pins at the high end of the list with TnnHOLD files, then trigger different pins every time you interrupt with a foreground sound. Either that, or make a longer file with the whole list of sounds you want to play.
